No Start, 1996 Chevrolet S-10
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=22820
Printed Date: April 01, 2026 at 8:49 AM
Topic: No Start, 1996 Chevrolet S-10
Posted By: mikekliebert
Subject: No Start, 1996 Chevrolet S-10
Date Posted: December 13, 2003 at 10:55 PM
I had to take my dash panels off on the driver's side of my 1996 Chevrolet S-10 pickup. After I installed a new power brake booster I put everything back together and the truck would not start.
I did not dsconnect any wiring, alarm or otherwise. The truck lights and everything else electrical comes on except the truck won't start. I had a simple alarm installed by a local alarm shop when I bought the truck. The alarm still works as it should.
Is there a reset button or something that I need to reset so the truck will start, and if so where is it?
I would really appreciate any advise on this and maybe the name of an alarm person around Dallas,TX who could come to my house if I can't figure out the problem. I live near South Mesquite, TX.
Mike
Posted By: auex
Date Posted: December 13, 2003 at 11:21 PM
Does the truck crank? Or does the truck crank and not start? Is there a security light in the dash that turns on or flashes? What wires did you tie into for the brake booster for power/ground? If the truck is a manual transmission, did you by any chance knock the pin switch on the cluth loose ( if you did this then the truck doesn't think that you are pushing on the clutch to start it)?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: December 14, 2003 at 12:06 AM
The truck does not crank. The security light on the dash was removed because one of the wires pulled out of it   when I pulled off the dash panel. I was thinking it might be ok to do without this light, I hope so. The brake booster is actuated by a vacuum hose to it off the intake manifold. It does have a small plastic piece that goes between the brake petal arm and the brake petal arm clip. It's an automatic transmission. Thanks.
Mike
Posted By: auex
Date Posted: December 14, 2003 at 12:15 AM
Try pulling the main power fuse for the aftermarket alarm and see if it will start. Also check and make sure that the connections for the starter kill didn't come undone.
Date Posted: December 14, 2003 at 12:46 AM
I unplugged two fuses near the alarm but it did not start up. I don't find any other ways to salve this. Thanks
Mike
Posted By: Teken
Date Posted: December 14, 2003 at 12:57 AM
1. You will need to find the over ride switch as a starter.
2. The fact that the vehicle does not start even with the fuses removed, indicates you have a N.O relay starter inhibit circuit.
If you locate the alarm CPU, it wont matter if you unplug it. It will not start, as it requires the alarm to send a ground to close the contacts.
3. Worst case, you pull the whole unit out and rewire the ignition with new wires, to enable you to start the vehicle.
4. Some alarms, for what ever reason require that the LED is active, to function properly. Try to repair the broken leads and try again.
5. After you re-install both fuses for the alarm, remove the negative battery terminal of vehicle.
Wait one minute (60 seconds) to allow the alarm to drain. Attatch the battery terminal back on and listen for any clicks from the alarm unit.
Try to start the vehicle again.
6. Check the basics, is the battery even above 12.8 volts?
Regards
EVIL Teken . . .
Posted By: JeremyB
Date Posted: December 14, 2003 at 9:00 AM
try finding your starter wire, should be yellow but watch out your air bag wire is also yellow but should have a tag on it somewhere indicating it is for the SIRS system. Should be able to put a jumper in the yellow wire after removing the relay or just put one of the two yellow ends on the unused relay post(if you haven't powered the alarm yet). You could check to see if it starts with the key in the on position and jumping across the starter
