1995 nissan 240sx engine start HELP!
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=2283
Printed Date: April 09, 2026 at 8:18 AM
Topic: 1995 nissan 240sx engine start HELP!
Posted By: mr_timluu
Subject: 1995 nissan 240sx engine start HELP!
Date Posted: July 28, 2002 at 12:30 AM
hi....love the site....i have a
CLIFFORD AVANTGUARD G4 w/ INTELLISTART
can anyone tell me where i am suppose to put a relay for the engine start. the car has to crank twice in order to start the engine and it causes an overcrank on the second time... there are i believe 2 IGNITION WIRES, 2 STARTER WIRES on the car, the intellistart has 2 IGNITION WIRES and 2 A/C HEATER WIRES and 1 STARTER WIRE....i was told to use a relay and dont know how to use it for the second ignition or the second starter or use resisters and diodes to a relay to prolong the starter signal to crank longer....if i want to do this..what kind of diodes and resisters or relay setup....i have been working on my engine start for 3 days with only little luck of starting the engine...
THANKS TO ANYONE AND EVERYONE WHO PROVIDES ANY INFO
Posted By: Velocity Motors
Date Posted: July 28, 2002 at 8:41 AM
Nissan
240SX
1995
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK / YELLOW
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK/ RED
Ignition #2:
WHITE
Ignition  #3:
N/A
Accessory:
WHITE/ BLUE
Brake  Light:
RED / GREEN (+)
SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
YELLOW/RED
PIN 3 AT ECCS *
Parking Lights:
RED / BLUE
(+) AT HEADLIGHT SWITCH
Headlights:
SEE NOTES BELOW
OEM Alarm  Disarm:
GREEN/ YELLOW (-)
SAME CONNECTOR AS DOORLOCKS
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Electronic Concentrated Control System (ECCS) Module Located In Pasenger Kick Panel. Pin #2 Is Also YELLOW/RED Tach Wire. These Wires Are On Short Side Of Connector Near Center Bolt. LT. GREEN/ BLUE At Distributor Is High Signal. ** This Vehicle Is Equipped With Two Start Wires. Both Must Be Powered In Order For Vehicle To Start When Engine Is Cold
Nissan
240SX
1995
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE
IGNITION SWITCH HARN.(WHT/RED FOUND)
Starter  Kill:
BLACK / YELLOW
Ignition  +12 Volts:
BLACK/ RED
Dome  Lights/Superv:
RED / WHITE
(-) DRIVER KICK PANEL ***
OEM Horn:
GREEN / WHITE (-)
STEERING COLUMN HARNESS OR AT RELAY
Power  Lock:
LIGHT GREEN / WHITE
@ WHITE 12 PIN CONN. IN DR. KICK ****
Power  Unlock:
BROWN / RED
Trunk  Release:
N/A
Alarm  Input Wire:
RED / WHITE
Notes:
*** SE Models Are Diode Isolated. Wire In Bottom Row Of Main Body Harness Conn. In Driver Kick Panel. Proper Wire On Base Model Is BLUE. ****  Negative Pulse Door Lock
The starter wire you must run in two wires and connect to one on the starter module on the Clifford.
Date Posted: July 28, 2002 at 1:25 PM
i looked up the wire diagram in a recent post and already have this info........there is one starter wire coming from the clifford intellistart......and the nissan has 2 starter wires.....how do i hook up this one wire to 2 starter wires...do i hook up to the key side or coil side or tap or splice a wire..
Date Posted: July 28, 2002 at 1:44 PM
    What you have to do is solder 2 wires onto the Clifford starter wire and then take one of each and attach to each starter wire. That's it, your done.
Date Posted: July 28, 2002 at 11:28 PM
thanks...
Date Posted: July 29, 2002 at 8:12 AM
no problemo posted_image
