2003 ford explorer bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23042
Printed Date: April 23, 2026 at 11:01 AM
Topic: 2003 ford explorer bypass
Posted By: muaiad97
Subject: 2003 ford explorer bypass
Date Posted: December 18, 2003 at 7:34 PM
hi all
I need easy way to bypass the system in ford exeplorer 2003.instead using
the bypass moduel to make the remot starter working.
Posted By: auex
Date Posted: December 18, 2003 at 8:13 PM
You don't. Depending on the key you may be able to take the pellet out and glue it to the cylinder, but you will have to take the pellet out of all the keys.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: misterjimbo
Date Posted: December 18, 2003 at 8:48 PM
if you cut the transponder out of the key and glue it to the cylander you are going to have one small problem. if your car gets stolen and the insurance company investigates they do not have to accept your claim because you defeated the biggest security feature on the car.
Posted By: auex
Date Posted: December 18, 2003 at 8:49 PM
I didn't say it was the smartest thing, just that it could be done.
Date Posted: December 18, 2003 at 8:58 PM
i understand i just like to let people know the concequences. i have helped ins. companies check for fraudulent claims on theft recoveries and have seen them bounce claims because if this. i thought it was a myth until i saw them do it.
Posted By: muaiad97
Date Posted: December 18, 2003 at 8:59 PM
thanx all
but i heard another thing i am not sur how to do it that wrap wire around the cylender then conected to relay #30&87    #85 to igni  #86 to ground.
someone knows about this
Posted By: auex
Date Posted: December 18, 2003 at 9:06 PM
Misterjimbo, I completely understand. My entire job is based solely around vehicle theft. I also work with the police so I hear all the stories. Any bypass that needs a key, wether the key is destroyed or not, to work just makes it extremely easier for a thief to steal the car.
Posted By: cableguy13011
Date Posted: December 20, 2003 at 12:33 PM
hey theres a dei bypass called 555f it a pelet you program it to the car only turns on when you remote start it leave the factory system the same
Cableguy!!!
Posted By: blatant3
Date Posted: December 23, 2003 at 6:58 PM
yeah you can do that.
wrap the wire around the 3rd key about 4 times, then you want to take the 2 remaining ends, and hook them to #30 & # 87 of a relay. hook another wire to #85, and run it to the switched 12vt wire, and run #86 to the active output of the remote starter. then program the key and youre set.
good luck
blatant3
Posted By: blatant3
Date Posted: December 23, 2003 at 7:00 PM
dont forget to wrap the loop around the ignition cylinder too (forgot to type that part). youll want to make the loop around the cylinder twice, or it wont work
blatant3
