flashing headlights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23051
Printed Date: April 23, 2026 at 7:14 AM
Topic: flashing headlights
Posted By: dyer
Subject: flashing headlights
Date Posted: December 18, 2003 at 11:19 PM
I would like for my headlights and taillights to flash in a wig-wag pattern. I would like for them to go off when the alarm is triggered and when i activate them by a switch. I figure i need 2 whlen 2150a units. Is this correct? Any suggestions would be great.
Dyer
Posted By: Geeque
Date Posted: December 19, 2003 at 10:37 AM
Why?
You could probably get away with usin the alarms flashing light trigger and some 30A relays.
Gary Kline
MECP Master Technician
Posted By: Geeque
Isolate the triggers.
Gary Kline
Posted By: dyer
Date Posted: December 19, 2003 at 11:26 AM
i want the lights to flash in a series of patterns. The reason I need it on a switch is for use as a volunteer fire dept. vehicle. Thanks for the replies.
Dyer
Posted By: Teken
Date Posted: December 19, 2003 at 3:01 PM
If you wanted it to be a pattern, then yes using the Whellen, Federal, Nova star units would serve that purpose.
Just so you know the prices for 4-6 channel 90 watt strobe kit, has come down to almost $150.00 USD.
Those two units combined almost cost as much and do not offer the same level of flexability, nor the light penatration for distance as a standard strobe unit.
I would suggest that you take a look at a few key sites and compare prices.
The time involved is alot less for an entire pre-fabricated power supply with strobe heads, then it is for wiring it into your alarm, etc.
This was the same scenario I had to consider myself 3 years ago.
I havent looked back since, and have so much more flexability for effects and strobe patterns.
Just my thoughts
Regards
EVIL Teken . . .
