2002 galant, autopage rs-750
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23068
Printed Date: April 22, 2026 at 11:14 PM
Topic: 2002 galant, autopage rs-750
Posted By: roncoleman11
Subject: 2002 galant, autopage rs-750
Date Posted: December 19, 2003 at 10:09 AM
i need to find out how to interface the 555u with a autopage rs-750 and an update wire code if you have one please
Posted By: defective
Date Posted: December 19, 2003 at 10:13 AM
as for the 555u, i'm useless, i don't really use those units, and for the wire info, it's the same since 99. In case you dont have it, here it is.
Posted By: Geeque
Date Posted: December 19, 2003 at 10:20 AM
What do u need to know @ DEI 555U?
Gary Kline
MECP Master Technician
Date Posted: December 19, 2003 at 10:22 AM
if you dont use it how do you get pass the transponder, and how do you wire you the ignition for remote start.  i am a new installer and i am trying to get my training in by using my car. please help if you can it is a autopage rs-750. it says i dont need a relay for the ingition, but i dont see how that would work.
Posted By: Geeque
Date Posted: December 19, 2003 at 10:32 AM
You have to get a transponder bypass for that vehicle, DEI 555U, The remote start should already be wired for the ignition and everything you need. Any questions I'll be glad to answer them. Youll need to go to the dealer to get a key they dont need to cut it but they do need to program it. Usually runs between 20-30 dollars.
Gary Kline
Date Posted: December 19, 2003 at 12:10 PM
i Have a key to go inside of the box. just need help getting it installed
Posted By: Geeque
Date Posted: December 19, 2003 at 4:20 PM
There should be two wires coming out of box and a loop, blue wire goes to armed while running out put, and loop gets snuggly fitted around ignition solenoid, you might have to play with it to get it right.
Gary Kline
Date Posted: December 22, 2003 at 2:50 PM
does anybody know where the truck wire is for the alarm on a 2002 galant
Posted By: Velocity Motors
Date Posted: December 22, 2003 at 2:56 PM
white wire (- trigger )   at light in the trunk
