Nissan Skyline R32 wiring diagram.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=2317
Printed Date: April 08, 2026 at 2:22 PM
Topic: Nissan Skyline R32 wiring diagram.
Posted By: vassco
Subject: Nissan Skyline R32 wiring diagram.
Date Posted: July 28, 2002 at 11:00 PM
Hey all,
I m currently installing my car alarm into my car (Nissan Skyline R32 GTS-T, import) and need the wiring diagram to install it.
Any help would greatly be appreciated.
Vas
Posted By: Velocity Motors
Date Posted: July 29, 2002 at 8:10 AM
NISSAN SKYLINE GTR 2001
|              12V|WHITE/ blue          |+  |ignition harness            |
|          STARTER|WHITE/ green         |+  |ignition harness            |
|   SECOND STARTER|WHITE/ red           |+  |ignition harness            |
|         IGNITION|BLACK/ red           |+  |ignition harness            |
|        ACCESSORY|WHITE/ black         |+  |ignition harness            |
|       POWER LOCK|add actuator        |   |in driver door              |
|     POWER UNLOCK|                    |   |                            |
|       LOCK MOTOR|                    |   |                            |
|     UNLOCK MOTOR|                    |   |                            |
|    DISARM DEFEAT|                    |   |                            |
| PARKING LIGHTS +|RED / blue            |   |steering column             |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|                    |   |                            |
|     DOOR TRIGGER|PURPLE / white        |-  |driver side "A" pillar      |
| DOME SUPERVISION|                    |   |                            |
|  TRUNK/HATCH PIN|RED / white           |-  |trunk light                 |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|blue                |+  |in driver door              |
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|WHITE/ stripe        |   |any fuel injector           |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|WHITE/ green         |+  |brake pedal switch          |
|     HORN TRIGGER|GREEN/ orange        |+  |at horn                     |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|RED / wht - RED / blk   |A  |driver window switch        |
|  RF WINDOW UP/DN|blue - blu/red      |A  |driver window motor         |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
| SUN RF OPN/CLOSE|                    |   |                            |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|                    |   |                            |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|                    |   |                            |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|                    |   |                            |
|       RF SPEAKER|                    |   |                            |
|       LR SPEAKER|                    |   |                            |
|       RR SPEAKER|                    |   |                            |
Notes:
NOTE: To run wires into the driver door there is a rubber grommet behind the driver body side door harness plug.
This is all we have for this vehicle. We have some other information on a 1994 Skyline ( UK version ) but other than this, we don't see this vehicle in this part of the world posted_image
