auto start in 99 chev truck problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23416
Printed Date: May 11, 2026 at 11:47 PM
Topic: auto start in 99 chev truck problem
Posted By: viper91180
Subject: auto start in 99 chev truck problem
Date Posted: December 27, 2003 at 8:13 AM
the things been in the truck for a couple years so the model of the auto start is a coupoe years old, problem is it wont start with the button unless your right on top of the truck , anymore than 8 or 10 feet it wont start?????
Posted By: Velocity Motors
Date Posted: December 27, 2003 at 8:17 AM
Check to see if the antenna may have accidentally been unplugged or replace your battery in your remote control.
------------- Jeff
Date Posted: December 27, 2003 at 9:44 AM
both have been done, any other suggestions, i dont know if there is a programable feature for this or now:?????????
Posted By: serialthrlla
Date Posted: December 27, 2003 at 9:57 AM
putting the excess antenna wire in the headliner can help your range. and if it has or if you can turn off the codehopping in the programming. at least these are a couple things to help with DEI systems
Posted By: Alpine Guy
Date Posted: December 27, 2003 at 9:20 PM
the auto starts have had problems with range in older models, there is a fix, i will see if i can find it.
Posted By: sroth140
Date Posted: December 28, 2003 at 1:33 AM
i had a matrix rs 2 do that to me, i had to put the remote right on the glass over the antenna to disarm the car. i pulled the brain and replaced it with a new one. its been fine for the last two years after that.
