2001 tundra, need some tips
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23477
Printed Date: May 12, 2026 at 7:53 PM
Topic: 2001 tundra, need some tips
Posted By: profuse007
Subject: 2001 tundra, need some tips
Date Posted: December 28, 2003 at 12:14 PM
2001 tundra V8 sr5 fact alarm intergrated, need some tips
791xv
i need some tips upon this vehicle.
my diagram doesnt show much of complications, but if someone have done this car plz pinpoint out some tips on those hard to find wires. besides the unlock require 2x pulse on driver side, thanks to jworm...
Date Posted: December 28, 2003 at 8:53 PM
anyone....
------------- Houston,TX
Posted By: JWorm
Date Posted: December 29, 2003 at 12:47 AM
Tips? Its a Toyota....they don't get much easier.
When did I say unlock was double pulse?
12volts WHITE/ red or white + ignition harness
Starter GREEN/ black + ignition harness
Ignition BLACK / YELLOW + ignition harness
Second Ignition BLACK/ red + ignition harness
Accessory blue/red + ignition harness
Parking Lights- RED / black steering column
Horn Trigger GREEN/ red - steering column
Power Lock WHITE/ green - either kick panel
Power Unlock RED / yellow - either kick panel
Lock Motor blue/white drivers door harness
Unlock Motor BLACK / YELLOW drivers door harness
Parking Lights+ green drivers kick panel
Door Trigger WHITE/ blue - drivers door harness
Dome Supervision use door trigger
Factory Alarm Disarm blue/black - drivers door harness
Brake Wire GREEN / WHITE + drivers kick panel
Tachometer black or blu/wht instrument cluster, brn plug
Notes: It is black on the 6 cylinder models, and blue/white on the 8 cylinder models, at the instrument cluster. On the 4.7L V8 can also use BLACK/ blue at coil #1 on the drivers side.
What are you doing to the truck? Alarm, remote start, both?
If the lights have an "AUTO" option on the switch, you will need to factor that in when doing remote start. If the remote start times out, the lights will stay on until a door is opened. If you never open a door, the lights will stay on until the battery dies. Dumb design by Toyota. I can explain how to get around it if you need me to.
Date Posted: December 29, 2003 at 1:25 AM
nvm...i was searched through a wrong thing...
its a viper 791xv, so both alarm and rs
so i guess its a straight forward install tomrorow.
it would be cool if you could explain about how to disable the "AUTO" light after remote start, i may have to run into it if not next time.
Date Posted: December 29, 2003 at 1:26 AM
thanks jworm
Posted By: JWorm
Date Posted: December 29, 2003 at 9:14 PM
The following will turn off the AUTO lamps after the remote start shuts off either by remote or by shutting down after the programmed time.
86: +12 volts
85: (-) rearm output from remote start
87: ground
30: Drivers door trigger.
You need to use the true door trigger, not the one listed in the diagram above. Remove the factory pin switch to see the color of the wire.
If you are doing an alarm / remote start, its harder. Problem is pulsing ground to the door trigger will trigger the alarm. Solution is to cut the drivers door trigger, insert a diode inline (stripe toward door pin switch), and connect 30 from the relay above on the non-stripe side of the diode. Connect your door trigger wire from the alarm to the pin switch side (stripe side).
Other option is to keep light switch in off position when truck is off instead of in the AUTO position.
Date Posted: December 29, 2003 at 10:35 PM
thanks jworm, the install today works out great, theres no auto light thingy.
koo, got it. didnt think of putting the diode. i thought of pulsing the trigger, too but the alarm will go off, like you mention.
