2001 Mercury Mountaineer Remote Start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23500
Printed Date: May 13, 2026 at 2:37 AM
Topic: 2001 Mercury Mountaineer Remote Start
Posted By: McFitz
Subject: 2001 Mercury Mountaineer Remote Start
Date Posted: December 28, 2003 at 6:22 PM
Hello all,
I have installed a number of systems in the past but have now discovered an issue with my Mountaineer and need some input based on reading a few of your topics.
This time I'm having the system installed by a local dealer and am told that l need to supply a PATS key that is used on my vehicle to be placed high up in the dashboard so the remote start that they will be installing will be able to function properly.  Now correct me if I'm wrong but doesn't that defeat the purpose of having the microchip in the key and taking it with you when you leave the vehicle.  I've noticed the bypass modules mentioned in many of your topics but the three local installers want to use the key.  I just don't want to come back to my car after a long days work and see another vehicle sitting in its place.
Please feel free to give me any feedback that you may have on this issue.
Posted By: JWorm
Date Posted: December 28, 2003 at 7:07 PM
There are three different versions of the PATS system that Ford has. For two of them, DEI makes a bypass module that doesn't require a key. Unfortunately, you have the third system which DEI (and most other bypass module companies) doesn't make a bypass for. You can find a bypass module at www.bypasskit.com that works with your vehicle that doesn't require a key. They are expensive, over $40. I think the model number is PKU-F2. Typical bypasses for other cars cost dealers less than half that.
My shop has purchased blank Ford transponder keys from a key vendor and we sell them to customers. We use those keys (Uncut) to temporarilly bypass the Pats system. We make money selling them a key, and the customer saves money by not paying a dealer the $60+ that a dealer will typically charge.
Keeping the key in the vehicle up under the dash is not that bad of an idea if done properly. My shop breaks the metal part of the key off so if it was found by a thief they couldn't just start the vehicle and drive away. It is also taped up and totally out of view when looking under the dash area.
On the other hand, the shop down the street from mine is totally different. They use bypass modules that require a spare key for almost every vehicle with a transponder. They make no effort to make it hard to steal the vehicle. Numerous times we have looked under the dash of one of those vehicles and opened up the black box with the key in it and started the car. We always do it with the customer watching us. They are amazed how easy it would have been to steal their car. Less than 15 seconds and I could be driving down the street.
Posted By: NowYaKnow
Date Posted: December 28, 2003 at 7:45 PM
If your that worried about it you can source out a bypass for your vehicle that doesn't require a key. They would then just need all the keys you have for your vehicle in order to program the bypass, but no keys would be in the dash. Assuming it's a ford dealer they should be able to get these parts for you. Go talk to the parts counter guy and see if he has any in stock or can order one for you. The ford bypass part numbers are as follows:
1L3Z-19G365-AB
1L2Z-19G365-AB
1S4Z-19G365-AB (Focus, Escape, T-Bird)
You will need either the 1L3Z or the 1L2Z. The information I have lists the 2001+ mountaineer as needing the 1L3Z and the 2002+ as needing the 1L2Z bypass. The following pic will help you choose the right one for your vehicle:
posted_image
By the way, another option would be to get a key make sure it is programmed to the vehicle and will start and run it, then just cut the key apart or grind it down and have them put the head of the key in the box. This way nobody can take that key and use it in the ignition. I've never needed to put the key in the dash on a ford/lincoln/mercury so there is definately other options available. Good luck,
Mike
