2003 chevy cavalier remote start/keyless
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23722
Printed Date: May 04, 2026 at 2:31 AM
Topic: 2003 chevy cavalier remote start/keyless
Posted By: jpk217024
Subject: 2003 chevy cavalier remote start/keyless
Date Posted: January 01, 2004 at 5:52 PM
i need a wiring diagram for this vehicle, in order to install a remote starter,keyless entry....
any help would be greatly appr...           thankyou,
Posted By: boomer_106
Date Posted: January 02, 2004 at 2:00 AM
CHEVROLET CAVALIER 2000 - 03
WIRE COLORSLOCATION
12 VOLTS CONSTANTREDIGNITION SWITCH HARNESS
IGNITION 1PINKIGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1ORANGEIGNITION SWITCH HARNESS
STARTERYELLOWIGNITION SWITCH HARNESS
PARKING LIGHTSBROWNDRIVERS KICK PANEL HARNESS to the REAR
DOMELIGHTGREEN/ BLACK & LT. BLUE ( - )SEE NOTES *1  & *2
PWR DOOR LOCKLT. BLUEEITHER KICK PANEL *3
PWR DOOR UNLOCKWHITEFACTORY KEYLESS (TYPE A)   W/O FACTORY KEYLESS (TYPE C)
TRUNK RELEASEBLACK/ WHITE (+)@ BCM *2
TACH SENSORVIOLET/WHITE (AC)@ ENGINE HARNESS *4
BRAKEWHITE (+)@ BRAKE SWITCH
HORNGREEN or BLACK ( - )@ STEERING COLUMN
FACTORY DISARM   N/A
FACTORY ANTI-THEFT TYPEPASSLOCK II
NOTES:
*1 - The GREEN/ BLACK is located in the lower driver kick panel. It catches the driver door only.  The LT. BLUE is located in the passenger kick panel and it catches the passenger door. Tap both wires and diode isolate each. Also found at the BCM.
*2 - The BCM (Body Control Module) is located to the left of the steering column above the driver kick panel.
*3 - On vehicles without keyless entry, locks are 5 wire (type C) and are mastered from the passenger side switch.  On vehicles that do have factory keyless, the locks are positive trigger (type A). Also found at the BCM
*4 - The engine harness is found next to the battery, below the radiator hose, just above the transaxle.
Posted By: draasch
Date Posted: January 02, 2004 at 8:09 AM
Make:   Chevrolet
Model: Cavalier
Year:    2003
This Database Was Last Updated On:    6/9/2003
Index #: 7396
here is what i have for that car...double check all wires with a meter..
Alarm
Constant 12 volts RED IGNITION SWITCH HARNESS
Ignition 12 volts PINK IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light RED / WHITE (-) AT ANTI-THEFT MODULE BEHIND GLOVEBOX
Trunk Pin Switch BLACK (+) AT LIGHT IN TRUNK
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock LIGHT BLUE PASSENGER #203
Power Unlock WHITE KICK PANEL
Remote Start
Tach Signal WHITE LARGE HARNESS ON FRONT OF ENGINE #238
Ignition #2 WHITE IGNITION SWITCH HARNESS
Ignition #3
Accessory ORANGE IGNITION SWITCH HARNESS
Neutral Safety YELLOW (-) IGNITION SWITCH HARNESS
Brake Light WHITE (+) AT SWITCH ABOVE PEDAL
Reverse Light LIGHT GREEN (+) IN HARNESS TO TRANSMISSION
Rear Window Defrost
#238 See General Motors Passlock ll Diagram
#203 See Reversal Rest At Ground Door Lock Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
