Viper Alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=23736
Printed Date: May 04, 2026 at 12:21 PM
Topic: Viper Alarm
Posted By: meh66
Subject: Viper Alarm
Date Posted: January 01, 2004 at 8:09 PM
Need Help. I just installed a viper 550 HF alarm and eveything seem ok. The alarm works fine during warmer temperatures, but when the sun goes down and the temperature is in the high thirties, the alarm is dead. The car starts ok with the key and I measure 12 volts across the battery before cranking. I do notice when I push the power door lock button the led lights up. I am totally confused on this problem. I wiggled the wire harnesses for both the car and alarm but no change. ------------- MEH66
"Car Performance and Mobile Electronic Enthusiats"
Posted By: ck auto
Date Posted: January 01, 2004 at 9:24 PM
how did you connect wires solder or crimps if it is a 550 hf it is also a remote starter
------------- good luck
kirk
Posted By: meh66
Date Posted: January 01, 2004 at 9:55 PM
The unit was used when I got it, my connections to the vehicle wire harness is soldered, but some of the connections already made were crimped. Thanks for the reply.
------------- MEH66
Posted By: meh66
Date Posted: January 05, 2004 at 10:05 AM
Kirk, What is the better way to connect the alarm? Solder or crimps? I have installed many car stereos and I usually solder the connections and I never had any problems with the connections. Thanks for your help. ------------- MEH66
Posted By: ck auto
Date Posted: January 05, 2004 at 10:45 PM
hi soldering is the only way to go. check connection and check your solder joints sounds like cold solder joint. does it rs when warm ------------- good luck
kirk
Posted By: meh66
Date Posted: January 12, 2004 at 7:10 PM
Hi, I will check the joints, so you will know the entire alarm stops function not just the r.s. Thanks for your input. ------------- MEH66
Posted By: Teken
Date Posted: January 12, 2004 at 7:21 PM
Is the battery supply 12 volts, or is it above?
ie. 12.8 VDC
Posted By: jrilla
Date Posted: January 12, 2004 at 7:33 PM
Check to make sure you have a good source for ground. Pretty basic, but thats a wierd problem.
------------- J Rilla
Owner/Installer
