Valet 562T Help 1996 Dodge Ram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24054
Printed Date: May 15, 2026 at 7:41 AM
Topic: Valet 562T Help 1996 Dodge Ram
Posted By: gokeeper
Subject: Valet 562T Help 1996 Dodge Ram
Date Posted: January 06, 2004 at 5:15 PM
I bought a valet 562t Remote start But it does not say where to connect the STATUS OUTPUT, ACCESORY RELAY TRIGGER, IGNITION RELAY TRIGGER, OR STARTER RELAY TRIGGER. these wires are all (-) 200mA wires and i have no clue where they go i have hooked up every thing else and the door locks pulse and lights flash but the remote start will do nothing not even click.
Also the door locks pulse but do not unlock or lock the doors.. Its a 1996 dodge ram and i tested the wires there were voltage on theer when u press the door lock and unlock buttons... Itsa Dodge diesel if it makes a difference...  Any help will be appreciated thanks ASAP...
Posted By: draasch
Date Posted: January 06, 2004 at 5:27 PM
see if this info helps....also post a link for the unit you are installing....
Make:   Dodge
Model: Pickup - Fullsize
Year:    1996
This Database Was Last Updated On:    6/9/2003
Index #: 2904
Alarm
Constant 12 volts RED & PINK/BLACK IGNITION SWITCH HARNESS
Ignition 12 volts D BLUE IGNITION SWITCH HARNESS
Starter D BLUE / YELLOW IGNITION SWITCH HARNESS
Dome Light YELLOW (-) DRIVER PIN SWITCH
Trunk Pin Switch N/A
Parking Lamp BLACK / YELLOW (+) AT HEADLIGHT SWITCH
Power Lock ORANGE / VIOLET IN BLACK CONNECTOR #203
Power Unlock PINK/VIOLET BEHIND PARK BRAKE
#203- See Reversal Rest At Ground Power Window Circuit Diagram.
Remote Start
Tach Signal GRAY/L BLUE AT POWERTRAIN CONTROL MODULE *
Ignition #2 BLACK/ ORANGE IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory BLACK/ WHITE IGNITION SWITCH HARNESS
Neutral Safety BLACK/ WHITE (-) AT SWITCH ON TRANSMISSION **
Brake Light WHITE/ TAN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light VIOLET/BLACK (+) AT SWITCH ON TRANSMISSION
Rear Window Defrost N/A
* Powertrain Control Module Located On Passenger Rear Of Engine On Firewall. ** BLACK/ WHITE (-) Wire Also Located At Powertrain Control Module.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: gokeeper
Date Posted: January 06, 2004 at 5:31 PM
I have hooked those up this is an auxillary harness the vallet seams a little wierd to me the link is https://www.directed.com/guides/manuals/ig/valet/N562T_6-03.pdf that is the install manues the auxilery harnedd is off the relay satellite ( well that is what they call it) the remote start ill not even engage the accesory so far...
Posted By: gokeeper
Date Posted: January 06, 2004 at 5:34 PM
one more thing if i groung STATUS OUTPUT, ACCESORY RELAY TRIGGER, IGNITION RELAY TRIGGER, OR STARTER RELAY TRIGGER. these wires are all (-) 200mA wires the starter and accerory and ignition will initiate but will not stop these wire must need to be connected to something but i'm not sure what.
Posted By: draasch
Date Posted: January 06, 2004 at 9:43 PM
hey go,
my computer is running really slow right now......its taking for ever to load pages.... i will try again tomorrow to help you....
Good Luck
David
Ace Security
813-376-9778
Tampa
Posted By: gokeeper
Date Posted: January 07, 2004 at 2:52 PM
i TALKED TO SOME TECH SUPPORT AND THEY SEAM TO THINK TEH UNIT IS BAD THE FIRST THAT THEY HAVE EVER HAD BAD IS WHAT THEY TOLD ME I FIND THAT HARD TO BELIEVE....
Posted By: gokeeper
Date Posted: February 09, 2004 at 10:34 PM
does this ram have typpe c door locks so i need two relays right?
Posted By: kgerry
Date Posted: February 16, 2004 at 1:40 PM
this little 4 pin harness is only used to power 3rd ignition or 2nd crank or Acc relays...these are all low current negative out to active extra relays..in most installs you can throw this harness in a box and never use it..but only hook these wires up IF powering extra relays
Posted By: kgerry
Date Posted: February 16, 2004 at 1:41 PM
for door locks use a 451M module, it plugs right in
