96 toyota camry remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24235
Printed Date: April 03, 2026 at 11:34 PM
Topic: 96 toyota camry remote start
Posted By: erinh
Subject: 96 toyota camry remote start
Date Posted: January 09, 2004 at 1:27 AM
having trouble installing remote start on a toyota camry 96. i need a wire that is only on in run position, a "heater" blower wire. the site lists it as accessory and BLACK / YELLOW - but that is an ignition wire, any ideas?
Posted By: daniel2002p
Date Posted: January 09, 2004 at 8:45 AM
A ign is only on in the run position and as soon as that wire along with all the other ignitions and accesories (if applicable) is powerred up, it should work.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: erinh
Date Posted: January 09, 2004 at 9:33 AM
the BLACK / YELLOW is only on in run position, any ideas which wire may be the heater?
Posted By: jrilla
Date Posted: January 09, 2004 at 9:50 AM
BLACK / YELLOW is Accessory
BLACK/ Orange is Ignition
BLACK / YELLOW Should power the heater
J Rilla
Owner/Installer
Posted By: erinh
Date Posted: January 09, 2004 at 10:21 AM
sorry, its early - i meant to say BLACK / YELLOW is on in run and crank positions. BLACK/ orange is the same. so still not clear on which is the heater :(
now i also have a new problem - there are 2 power wires that are always on going to the ignition, white and WHITE/ red, today i accidently touched the WHITE/ red to a ground and i saw a spark, and now that wire has no power. i guess a fuse blew somewhere, any ideas of where it may be located? the car still cranks by key, so i wonder why there are 2 power wires like that going to it, if its even needed or could i even just splice into the white one?
Posted By: erinh
Date Posted: January 09, 2004 at 6:45 PM
ugh, update - i tried to actually crank the car, and it does not crank now. it just soundslike it is trying. i guess it needs that other power wire - can i just splice in to the other or where could i find the fuse?
Date Posted: January 09, 2004 at 7:47 PM
I would not recommend that.  Go into the fuse box under the hood and there should be 2 fuses labeled IGN one rated a 40amp and another one (but I do not know the amp rating).  Just replace the one that is blown, it should crank up right away.
    1.8L VVT-i I-4
Posted By: erinh
Date Posted: January 09, 2004 at 8:00 PM
ah, i found it - it was a 30amp fuse by the way. the car cranks again :) well i'm at least back to the point of if i can't get this thing working this weekend i can just pull it out and go back to using my keys posted_image i called bulldog and asked them what i should try, they said i should disconnect all the wires from the remote start unit except the power and ground and see if it cranks, and then add one wire at a time... guess i'll try that.
Posted By: erinh
Date Posted: January 10, 2004 at 4:00 AM
i disconnected everything tonight, and hooked up the remote start using the instructions on this site, i used:
white for 12v constant power
BLACK/ white for starter
black orange for ignition
BLACK / YELLOW for accessory
GREEN / WHITE for brake
green for parking ligthts
grounded the ground wire to chassis
still same as before :( when i plug in it will flash the parking lights when i hit start, but doesn't try to crank the car. any ideas? about to ready to give up on this. posted_image
Posted By: profuse007
Date Posted: January 10, 2004 at 10:15 AM
do you have some kind of starter inhibitor relay (starter kill)? if so, you may have putted the starter wire at the wrong side of the starter inhibitor relay (starter kill).
Houston,TX
Posted By: erinh
Date Posted: January 10, 2004 at 10:21 AM
do you mean like some kind of factory protection? i don't think so. posted_image
Date Posted: January 10, 2004 at 10:36 AM
did you installed a relay b/t the camry's starter wire (BLACK/ white)? you said that it didnt crank when you hit start. i assumed that you plug in the starter wire(rs unit) to the BLACK/ white, since the unit starts up.
the starter kill relay is w/ the rs unit, not factory, so did you installed one?
Houston,TX
Posted By: erinh
Date Posted: January 10, 2004 at 11:24 AM
the remote starter unit is a bulldog security rs 102 ( https://www.bulldogsecurity.com/pdf/RS102_112_122.pdf ).
the unit has an 18 wire harness and a 4 relay harness, there is a wire coming from one of the relays that plugs into that BLACK/ white starter wire - and i did connect it to that. i'm guessing that relay is the starter kill relay?
thanks for trying to help me, i was about to the giving up point.
Date Posted: January 10, 2004 at 12:00 PM
dont give up...let me take a look at the manual
Houston,TX
Date Posted: January 10, 2004 at 12:13 PM
it seems like you dont have a starter kill relay. i hvent install one of these bdog unit.
at the starter/crank wire of the unit, yellow/blk, test the wire while starting rs.
i am stump on the ignition input wire on the 18pin, cant figure what it is. theres not enough info for installer like other companies do provide.
Houston,TX
Posted By: erinh
Date Posted: January 10, 2004 at 12:14 PM
thanks for helping! this is the first time i've hooked something up like this, only done cd players before.
i have one question: i hooked the wires from the rs to the ignition harness where the red arrow is pointing. there is a plugin where the yellow arrow is pointing, to the right runs to where the key goes in. the other side runs to under the hood, is it okay the i spliced in where i did?
posted_image
Posted By: erinh
Date Posted: January 10, 2004 at 12:16 PM
oops, my picture didn't come out - my wires are spliced in on the side of the connector that runs under the hood. is that okay?
i can go test what you want me to now - do you just want me to check how much voltage there is in different key positions or when i press the start button on the remote?
Posted By: erinh
Date Posted: January 10, 2004 at 12:21 PM
i'll wait for your post to see exactly what you want me to test.
in the meantime, their tech support just called me back and he told me to try a test off their webpage:  https://www.bulldogsecurity.com/pdf/relayharness.htm
gonna run out there and try it real quick.
