car starts then dies rs 97 grand prix
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24237
Printed Date: April 04, 2026 at 12:01 AM
Topic: car starts then dies rs 97 grand prix
Posted By: lazyike
Subject: car starts then dies rs 97 grand prix
Date Posted: January 09, 2004 at 2:09 AM
i have a 1997 pontiac grand prix with a crimestopper rs 900 starter.  This car does not have an alarm or pass lock.
about 50% of the time the car will start run for 3 secs. then shuts off, the r/s has 3 attempts and it will keep trying to start the car but it will not continue to run.  It has always done this.
other than that everything woks fine the other 50% of the time.
Posted By: daniel2002p
Date Posted: January 09, 2004 at 8:42 AM
Make sure that you have a good tach signal.  Put your meter on the tach wire and set it to AC voltage.  The reading should vary between 1-6v and increase with RPM.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: lazyike
Date Posted: January 09, 2004 at 1:12 PM
thanks daniel....
I thought that but the rs 900 has a smart tachless mode of which I am using....   should I set it in tach mode and start using the tach sensor?
Date Posted: January 09, 2004 at 7:55 PM
I would recommend that very much, on some cars the tachless option does not work, so you have to use the tach, use it and it will solve everything.  Let me know how it goes.  By the way I looked at that alarm install intructions, and it is not very clear on the tachless mode, so use a tach.  You will find it at the fuel injectors, it will be the odd colored wire compared to other ones.
    1.8L VVT-i I-4
Posted By: sparkie
Date Posted: January 10, 2004 at 5:17 PM
Check to make sure that you have powered up both ignition circuits. There is a pink wire and either a white or purple wire that is another ignition wire. Does your car have VATS? If there is a resistor in the key then check to make sure that it is correctly interfaced with. Not all Grand Prix's had VATS, but some did.
sparky
