2003 Mazda 6 remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24272
Printed Date: April 05, 2026 at 12:31 PM
Topic: 2003 Mazda 6 remote start
Posted By: freakystyley990
Subject: 2003 Mazda 6 remote start
Date Posted: January 09, 2004 at 5:09 PM
I am doing an autostart in a 2003 Mazda 6 sedan. Does anyone have a wiring chart for this vehicle? It is NOT the mazda 626, just the mazda 6 2003 sedan.
Posted By: Teken
Date Posted: January 09, 2004 at 5:31 PM
The vehicle is based on the 626, and is now only named the 6 series.
I did not find any wiring information for this vehicle. So, it comes back to basics, in measuring all the wires from scratch.
Which should be done, regardless of what is provided to you.
Sorry I could'nt help.
Regards
EVIL Teken . . .
Posted By: daniel2002p
Date Posted: January 09, 2004 at 7:50 PM
I just put one in the other week, use the 2002-2003 mazda 626 wiring diagram, but some wires have different color tracers on them, like lock/unlock, and door trigger.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: Teken
Date Posted: January 09, 2004 at 9:55 PM
Mazda
626
2000-2002
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   GREEN
IGNITION SWITCH HARNESS *
Ignition #1:
   BLACK/ WHITE
Ignition #2:
   BLACK/ RED
Ignition #3:
   N/A
Accessory:
   BLUE
Brake Light:
   WHITE/ GREEN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
   RED, GREEN OR WHITE
AT COIL MODULE **
Parking Lights:
   RED / WHITE (+)
IN GREEN PLUG AT FUSE BOX
Headlights:
   YELLOW (-)
AT SWITCH
OEM Alarm Disarm:
OEM Alarm Arm:
Diesel Glow Plug:
   N/A
Clutch Bypass Wire:
Notes:
   * This vehicle is equipped with a transponder immobilizer system. See Installation Note #144 - Bypassing Transponder Theft Systems. An Additional Antenna Ring May Be Spliced In, P/N From Mazda Is GG2C-66-938. ** Note: Red and Green Are For 4 Cylinder Motor And White Is For 6 Cylinder Motor.
Mazda
626
2000-2002
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   BLACK
Starter Kill:
   GREEN
Ignition +12 Volts:
   BLACK/ WHITE
Dome Lights/Superv:
   RED / WHITE (-)
OEM Horn:
   GREEN/ RED OR GREEN/ ORANGE (-)
IN STEERING COLUMN HARNESS
Power Lock:
   BROWN / YELLOW (-)
AT TAN MODULE NEAR HOOD RELEASE
Power Unlock:
   WHITE & BROWN / WHITE (-)
AT TAN MODULE NEAR HOOD RELEASE ***
Trunk Release:
   ORANGE (-)
Alarm Input Wire:
   RED / WHITE (-)
Notes:
*** White Wire Only Unlocks The Driver's Door. The BROWN / White Wire Unlocks The Remaining Doors. Use Both And Diode Isolate Each Wire. See also Note #201 Negative Trigger Door Locks
