Prostart CT-3300 and 2003 Dakota
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24392
Printed Date: April 08, 2026 at 2:38 PM
Topic: Prostart CT-3300 and 2003 Dakota
Posted By: Krazyjay95
Subject: Prostart CT-3300 and 2003 Dakota
Date Posted: January 11, 2004 at 8:17 PM
I would like to put his feeler out for any advice or install info regarding installing a Prostart CT-3300 in my Dodge Dakota. I have the sentry key (Grey Key) , Factory security and remote keyless entry. I would love any info any of you have regarding the install. Thanks in advance
Posted By: ck auto
Date Posted: January 11, 2004 at 11:35 PM
hi im assuming your in canada not cambodia how much experience do you have in installs.search posts for wireing info or check out www.autocommand.com------------- good luck
kirk
Date Posted: January 12, 2004 at 9:18 AM
Thanks Kirk I have done one in my wiges 97 cavalier but I kept finding out that I needed more parts so this time I want to go in prepared.
Posted By: ck auto
Date Posted: January 12, 2004 at 9:52 PM
hi this one is a little tricky you have 2 acc as well as 2 nd ing and it uses resitiors for door locks i don't recommend a keyless bypass for dodges haven't found one i like yet i ussually just use a key i get them cheap enough if you need wireing inf let me know ------------- good luck
kirk
Date Posted: January 28, 2004 at 1:33 PM
Thanks ck auto, I was wondering igot the starter installed and used the 5th relay for the second ignition so do I need to connect a relay in order to conect the second accessory wire?
Posted By: ck auto
Date Posted: January 28, 2004 at 7:27 PM
hi yess you do what did you hook the green wire to you 2nd ing if you did hook it to 2nd acc and use a relay run off your whitre wire in your lock and arm harness to power that relay any ? just ask. ------------- good luck
kirk
Date Posted: February 02, 2004 at 10:40 PM
I'm not sure what you mean, On the autostart site There is a diagram on how to install a extra relay to hook up the second ignition...Is that what you mean or are you talking about something else. I am using the green 5th relay wire for the second ignition.
Date Posted: February 02, 2004 at 10:42 PM
Hey Kirk, I am using the green 5th relay wire for the second ignition do I just need another relay in order to connect to the second accessory???
Posted By: ck auto
Date Posted: February 03, 2004 at 5:30 PM
yes thats what you need to do to power you acc pin 85 to 12v pin 86 to ground out when running pin 87 to 2nd acc wire and pin 30 to 12v fused power ------------- good luck
kirk
Posted By: soultinter
Date Posted: February 03, 2004 at 6:27 PM
do you know what the eqivalent american model remote start for that system is? is it an as-1424 or something different?
Posted By: ck auto
Date Posted: February 03, 2004 at 7:37 PM
the closest one would be the as 1424 the ct 330 is a canadian tire model made by autostart it is identical to the 1424 except maybe the range is a little different.
kirk
Date Posted: February 06, 2004 at 6:19 PM
Thanks to all that helped I got the second accessory all hooked up and everything is working fine now.
Posted By: Craig3708
Date Posted: February 06, 2004 at 6:45 PM
Yes the CT-3300 is the same as thr AS- 1424... Craig.........
Yes the CT-3300 is the same as the AS- 1424... Craig.........
