2002 voyager door locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24583
Printed Date: April 04, 2026 at 6:12 AM
Topic: 2002 voyager door locks
Posted By: nkennedy
Subject: 2002 voyager door locks
Date Posted: January 14, 2004 at 5:17 PM
This is in regards to a remote starter lock/unlock.  I have been able to isolate both the lock and unlock functions with the proper resistors and relays.  However I am having problems hooking up both up together.  Any suggestions or diaagrams are appreciated.
Thanks.
Posted By: BElec223
Date Posted: January 14, 2004 at 6:58 PM
sorry to get off the subject but how did you seperate them with the relays. do you h ave a diagram that would help me with mine. im doing the same thing. thanks
Posted By: daniel2002p
Date Posted: January 14, 2004 at 9:16 PM
What kind of problems, locks not working or what are we talking about here???
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: desh187
Date Posted: January 15, 2004 at 12:22 AM
SINGLE WIRE DOOR LOCK SYSTEM.VIOLET/DARK GREEN AT BCM REQUIRES GROUND PULSE THRU 5.3K OHM RESISTOR TO LOCK AND 2K TO UNLOCK.
Posted By: serialthrlla
Date Posted: January 15, 2004 at 1:01 AM
just hook up the two relays seperately then run both wires two PURPLE / green
