2000 4 runner remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24640
Printed Date: April 03, 2026 at 12:35 AM
Topic: 2000 4 runner remote start
Posted By: MikeHusain
Subject: 2000 4 runner remote start
Date Posted: January 15, 2004 at 3:57 PM
I was wondering if anyone had the wire diagram for a 2000 toyota 4runner. I have 2 sources but both have different info on it, ie: door lock wires. Can anyone help out. Much thanks.......
Posted By: Teken
Date Posted: January 15, 2004 at 4:14 PM
Toyota
4-Runner
1999-2002
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
GREEN/ BLACK
IGNITION SWITCH HARNESS *
Ignition #1:
BLACK/ RED
Ignition #2:
BLACK / YELLOW
Ignition #3:
N/A
Accessory:
BLUE/RED
Brake Light:
GREEN / WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
BLACK
AT IGNITER ON PASS. WHEELWELL **
Parking Lights:
RED / GREEN (-)
AT ALARM MODULE
Headlights:
RED (-)
AT HEADLIGHT SWITCH ***
OEM Alarm Disarm:
N/A
OEM Alarm Arm:
BLACK / YELLOW (+)
AT ALARM MODULE
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* 2000 Vehicles May Be Equipped With a Transponder Type ** BLACK Tach Wire Also Found In Data Link Connector On Driver Side Of Engine (4 Cyld.) Or At Engine Control Module Located Behind Pass. Dash (6 Cyld.) Or Can Also Be Found In 26 Pin Connector In Pass. Kick Panel On Both.
Toyota
4-Runner
1999-2002
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
WHITE/ RED & WHITE
Starter Kill:
GREEN/ BLACK
Ignition +12 Volts:
BLACK/ RED
Dome Lights/Superv:
GREEN/ BLACK (-)
AT DOME LIGHT
OEM Horn:
GREEN/ RED (-)
AT ALARM MODULE
Power Lock:
RED / WHITE (-)
WHITE CONN. ABOVE BLUE IN DR. KICK***
Power Unlock:
RED (-)
Trunk Release:
Alarm Input Wire:
GREEN/ BLACK (-)
AT DOME LIGHT
Notes:
** Fuse Block Located In Driver Dash. *** Child Safety Locks: RED / BLUE (-) In Same Conn. As Door Lock Wires Above. See Note #209 - See Child Safety Locks Diagram. Lock Wires Are Also Found At Alarm Module. Lock BROWN / White (-) Unlock GREEN/ YELLOW (-)
Posted By: Teken
Date Posted: January 15, 2004 at 4:16 PM
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=2000&make=Toyota&model=4-Runner&ID=18944&type=Alarm
Posted By: Teken
Date Posted: January 15, 2004 at 4:19 PM
TOYOTA 4-RUNNER 2000-02
WIRE COLORS LOCATION
12 VOLTS CONSTANT WHITE or WHITE/ RED
IGNITION 1 BLACK/ RED IGNITION SWITCH HARNESS
IGNITION 2 BLACK / YELLOW
ACCESSORY /HEATER BLOWER 1 BLUE/RED IGNITION SWITCH HARNESS
STARTER GREEN/ BLACK or BLACK IGNITION SWITCH HARNESS
PARKING LIGHTS GREEN (+) @ DIMMER or HARNESS to REAR
DOMELIGHT LT. GREEN/ BLACK ( - ) behind drivers side JUNCTION BLOCK in a 13 PIN PLUG
PWR DOOR LOCK BROWN / WHITE ( - ) PLUG BELOW FUSBOX
PWR DOOR UNLOCK GREEN/ YELLOW & BLUE / YELLOW ( - ) (TYPE B) *SEE DIAGRAM* *1
TRUNK RELEASE N/A N/A
TACH SENSOR BLACK @ DIAGNOSTIC PLUG *2
BRAKE
GREEN / WHITE (+) @ SWITCH ABOVE BRAKE PEDAL
HORN
GREEN/ RED ( - ) N/A
FACTORY DISARM
DISARMS WITH UNLOCK
FACTORY ANTI-THEFT
TYPE TRANSPONDER (on some)
NOTES:
*1 - The door lock wires will meter while turning the key in the passenger door key. cylinder. The GREEN/ YELLOW wire is the key cylinder UNLOCK wire, the BLUE / YELLOW wire is the unlock detection wire. Use both wires and diode isolate each.
*2 - The diagnostic plug is located on the drivers side of the engine compartment.
Date Posted: January 20, 2004 at 8:12 PM
I was wondering if anyone could possibly help me out. I installed two Remote start / alarms in a 2003 honda pilot and a 2000 toyota 4 runner, both with the same brand, Autopage rs 650. I am having the same problem with both vehicles, when remote starting, the alarm goes off. Does anyone have an Idea what the problem could be. I also have another problem with the 2000 4runner, its seems that when the vehicle has been running for a while, and if i try to remote start, it starts the car and the car runs for about 10 seconds and then shuts down. This is only happening to the 4runner and it only happens if the car is warmed up, if i remote start it in the morning or when the car has been sitting, it stays on and runs fine, (except for the alarm going off). Much Thanks........ MIke
Posted By: boomer_106
Date Posted: January 20, 2004 at 8:25 PM
Mike did you connect a disarm wire to the alarm? Sounds like you didnt. Your diagrams should tell you the factory disarm wire and location. Then you must send the proper polarity to that wire when remote starting. Your remote starter may have a ground when running output. Im not familiar with the autopage. Im afraid I dont know about the shut down when warm problem your having.
Date Posted: January 21, 2004 at 10:38 AM
no I did not hook up disarm wire. I think you are right because when it remote starts the factory horn alarm goes off, not the siren of the aftermarket alarm. For the disarm wire, does it need a pulse or a constant output because the alarm has a ground while running output not a pulse output. Thanks......
Posted By: profuse007
Date Posted: January 21, 2004 at 1:02 PM
you need to pulse the disarm wire, just like pressing the factory remote one time to disarm.
------------- Houston,TX
Posted By: Teken
Date Posted: January 21, 2004 at 4:29 PM
profuse007,
You need to empty your in box for PM's. I replied to you last week. LOL, and it said it was too full !!
Regards
EVIL Teken . . .
