2003 toyota camry wire info
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24756
Printed Date: March 31, 2026 at 2:58 PM
Topic: 2003 toyota camry wire info
Posted By: seanw
Subject: 2003 toyota camry wire info
Date Posted: January 17, 2004 at 12:24 PM
I'm installing a valet stand alone remote start in a 2003 toyota camry where I want the remote start to activate when the lock button is pushed twice to show two pulses to activate the remote start. The only problem is that the lock pulse also activates the factory alarm which won't let the car start. I have installed the 555u with the valet remote start.I was wondering if anyone out there has installed a similar remote start system that might be able to help me with the wiring info on this car and a valet remote start that activates with the factory keyless entry remote, where the remote start activates by hitting lock twice to keep the doors locked but at the same time disarm the alarm.I also diode isolated the start wire from the second start wire to keep them from feeding into one another,so if anyone has installed a system like this in this car I would deeply appriciate the help. thanks sean
Posted By: bmf1000d
Date Posted: January 17, 2004 at 12:46 PM
Are you trying to keep the locks and trunk pop all on one remote? Cause your Valet can do all that
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
