doorlock/unlock for 96’ nissan quest
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24876
Printed Date: May 13, 2026 at 12:32 PM
Topic: doorlock/unlock for 96’ nissan quest
Posted By: UncleJohnzy
Subject: doorlock/unlock for 96’ nissan quest
Date Posted: January 19, 2004 at 1:16 PM
Any help would be appreciate on locating lock/unl wire on 96 nissan quest. It shows positive on some wire i found, but i need neg wires.
Posted By: boomer_106
Date Posted: January 19, 2004 at 1:26 PM
Posted By: Velocity Motors
Date Posted: January 19, 2004 at 2:03 PM
POWER LOCK|GREEN / WHITE         |-  |left kick or console
POWER UNLOCK|GREEN/ orange        |-  |left kick or console
Posted By: dfiddy
Date Posted: January 19, 2004 at 10:18 PM
i just did a 94 villager, which is the same platform and i can agree with the wire colors,location, and polarity. If you go to the console you can also catch the park lights there too. Maybe even the door triggers but not too sure.
Date Posted: January 20, 2004 at 10:26 PM
k, here's the problem
both wires shown positive when i hit the lock/unlock switch. my unit only support neg. so i did reverse polarity, still it don't work right.
any idea how to wire this properly?
Posted By: dfiddy
Date Posted: January 20, 2004 at 10:35 PM
really? Did you try the kick and the console? Cause pretty sure they are neg. I went in the kick, but I found them in the console as well. Keep lookin' for the same wire colors and test all of them you can find.
Posted By: draasch
Date Posted: January 22, 2004 at 4:17 PM
yes they will show 12v...til you put a neg triger to them. then they will trip
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
