2001 honda accord wires and location
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=24986
Printed Date: May 12, 2026 at 12:49 AM
Topic: 2001 honda accord wires and location
Posted By: UncleJohnzy
Subject: 2001 honda accord wires and location
Date Posted: January 21, 2004 at 12:29 AM
Hello everyone,
 I have a few problems when trying to install remote starter on '01 accord, see if any one can help
*** doesn't work with out the key in place. started fine with the key tho, so what kind of security key do i dealing with. altho the green key icon flashing when key's in and off position. how to bypass this???
*** I can't find the right lock/unlock wire, even tho i follow the diagram here and tried to chased it. I found one wire coming out of the dr's door givn signal when i hit the switch and that's it.
*** couldn't locate the tach wire either, since this car's ign cap invisible.
*** can't locate the disarm wire, what's the best way to do this/
Help, Help, Help, appreciated
Posted By: Javelin3o4
Date Posted: January 21, 2004 at 12:38 AM
SECOND IGNITION|yellow              |+  |ignition harness            |
|        ACCESSORY|WHITE/ black         |+  |ignition harness            |
|       POWER LOCK|BLACK/ blue *2       |-  |passengers fuse box *3      |
|     POWER UNLOCK|orange              |-  |passengers fuse box *3      |
|       LOCK MOTOR|WHITE/ red           |   |drivers fuse box            |
|     UNLOCK MOTOR|*4                  |   |drivers fuse box            |
|    DISARM DEFEAT|lt. GREEN/ red       |   |*5                          |
| PARKING LIGHTS +|RED / black           |   |drivers fuse box            |
| PARKING LIGHTS -|RED / yellow *6       |   |steering column             |
|       HEADLIGHTS|blue/red            |-  |steering column             |
|     DOOR TRIGGER|BLACK/ white         |-  |passenger fuse box *7       |
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|orange              |-  |drivers kick panel *8       |
|         HOOD PIN|yellow/red or yellow|-  |hood pin switch or *13      |
|TRNK/HTCH RELEASE|WHITE/ red           |+  |drivers kick panel          |
|  FCTRY ALARM ARM|*9                  |   |                            |
|FCTRY ALRM DISARM|*9                  |   |                            |
| DISARM NO UNLOCK|blue                |-  |*10                         |
|       TACHOMETER|blue                |   |tach test connector *11     |
|      SPEED SENSE|blue/white          |   |*12                         |
|       BRAKE WIRE|WHITE/ black         |+  |brake pedal switch          |
|     HORN TRIGGER|lt. GREEN/ blue      |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|RED / yel - RED / blu   |A  |drivers door switch         |
|  RF WINDOW UP/DN|blu/wht - blu/yel   |A  |RF window switch            |
|  LR WINDOW UP/DN|RED / yel - RED / blu   |A  |LR window switch            |
|  RR WINDOW UP/DN|RED / yel - RED / blu   |A  |RR window switch            |
Notes:
NOTE:  This vehicle has an immobilizer system that needs to be bypassed when adding remote start.  Use DEI part number 555H or 555U.  *1 Must interrupt the wire between the keyswitch and the fusebox, not between the fusebox and the starter, to keep the check engine light from coming on.    *2 Use BLACK/ white for lock and GREEN/ red for unlock on LX models without factory security.  These wires are located in a two pin gray connector by the front of the drivers side fuse box.  *3 in a green 20 pin connector.  *4 yellow on the EX and lt. GREEN/ red on the LX  *5 located in the same plug as the door lock wires.  Also found in a 14 pin green plug at the drivers fuse box on the EX model.   *6 Only available on the EX model.  *7 In a green 4 pin connector.  *8 Above the hood release in a gray 18 pin connector.  On the DX & LX models, also found in a 2 pin connector behind the drivers fuse box.  *9 Arms and disarms with the door locks on the EX models.  The LX models arm only with the factory transmitter.    *10 On the EX the wire is located at the drivers power window switch, on the LX the wire is at the keyless/security unit which is attached to the drivers underdash panel.   *11 The tach test connector is located behind the battery on the 4 cylinder, and on a bracket attached to the drivers side strut tower on the 6 cylinder motor.  The tach test connector is a white 2 pin connector, and may be covered by a black rubber boot.  *12 Located at the first plug on the ECM, it is a 32 pin gray plug. The ECM plugs can be accessed by pulling up the carpet on the passenger side of the center console.  There are 4 plugs total.  *13 On the EX models it is in a green plug next to the passenger side fuse box.  On the LX models it is at the keyless/security unit, if equipped, which is attached to the driver side underdash panel.
Posted By: profuse007
Date Posted: January 21, 2004 at 12:44 AM
-tach wire: 4 cylinder---behind the battery usually taped to something, look for a loop and its a single wire.
-disarm wire is at the door cylinder, follow the wire comin from there. theres like 3 wires harness from that. i permanently disarm it by ground it.
-you can properly run a wire to the door, but thats hard to get through...good luck with this one
-doorlock:|       POWER LOCK|BLACK/ blue *2       |- |passengers fuse box *3      |
all new honda now have key chipped, use 555u(spare a key), 555h(i suggest this one w/o a key)
Houston,TX
Date Posted: January 21, 2004 at 1:00 AM
Thanx, ok where can i quickly get the 555u or 555h at, and doesn't difficult to install?
Date Posted: January 21, 2004 at 1:05 AM
Hey Lam Tran,
How do you know which vehicle have key chipped, pass keys, or stransponder? so i should stay away from them, since they're extra complicated
