2001 toyota tundra alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25054
Printed Date: May 10, 2026 at 11:45 PM
Topic: 2001 toyota tundra alarm
Posted By: junior22
Subject: 2001 toyota tundra alarm
Date Posted: January 21, 2004 at 11:41 PM
need diagram for a 2001 toyota tundra ..i am puting in a alarm ...thanks junior
Posted By: RufNUSD
Date Posted: January 21, 2004 at 11:51 PM
12volts white & WHITE/ red   +   ignition harness
Starter black   +   ignition harness
Ignition BLACK/ red   +   ignition harness
Power Lock gray   -   front of fuse box, 22 pin plug
Notes: These wires will test only by operating the key in the passenger door lock cylinder, not the rocker switch on the door.
Power Unlock purple   -   front of fuse box, 22 pin plug
Lock Motor blue/white   5wi DKP, 12 pin plug in pin 10
Unlock Motor blue   5wi DKP, 12 pin plug in pin 11
Disarm Defeat blue   5wi PKP, 12 pin plug in pin 9
Parking Lights+ green   +   back of fuse box, 12 pin plug
Parking Lights- PURPLE / red   -   front of fuse box, 22 pin plug
Hazards same as turn signals
Turn Signal(L) green   +   steering column
Turn Signal(R) GREEN / WHITE   +   steering column
Door Trigger     -   front of fuse box, 22 pin plug
Notes: The driver door trigger is green, the front passenger door trigger is GREEN / WHITE, and the rear door trigger is YELLOW /GREEN. Use all three wires and diode isolate each.
Dome Supervision comes on with unlock
Tachometer lt. GREEN/ black   ac   instrument cluster or
Horn Trigger GREEN/ red   -   steering column
Someone pass me that bottle.
Posted By: profuse007
Date Posted: January 22, 2004 at 12:00 AM
tach wire (blue/white) can be find on the 1st coil pack driver side for v8. there should be like 4 wires comin out of the coil.
black wire for v6 at the diagnostic connector, lil rectangular box (i think) on driver side.
everything else is pretty straight forward...very easy and roomy to work w/.
Houston,TX
Posted By: RufNUSD
Date Posted: January 22, 2004 at 12:11 AM
It must be Toyota night. Juniors booked tommorow.
Date Posted: January 22, 2004 at 12:14 AM
lol...talkin about toyota, my freakin toyota died on me....crap!!!! i want to say that i hate toyota but i just cant do that.
Houston,TX
