92 thunderbird tach wire location?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25084
Printed Date: May 10, 2026 at 2:13 PM
Topic: 92 thunderbird tach wire location?
Posted By: jboxer23
Subject: 92 thunderbird tach wire location?
Date Posted: January 22, 2004 at 5:28 PM
Is there anyone out there that can please tell me where the tach wire is located and what color it is in a 92 ford thunderbird?  Thanks to anyone who helps.
Posted By: draasch
Date Posted: January 22, 2004 at 5:39 PM
Remote Start
Tach Signal TAN / YELLOW ELECTRONIC ENGINE CONTROL MODULE *
Ignition #2 GRAY / YELLOW IGNITION SWITCH HARNESS **
Ignition #3 GRAY / YELLOW IGNITION SWITCH HARNESS **
Accessory BLACK/ LIGHT GREEN IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light LIGHT GREEN (+) SWITCH ON BRACKET ABOVE BRAKE PEDAL
Reverse Light BLACK/ PINK (+) AT SWITCH ON TRANSMISSION
Rear Window Defrost
* Located At Pin #4 At Electronic Engine Control (EEC) Module (3.8L Supercharged Tach Wire Is TAN / YELLOW). EEC Module Located In Under Hood Compartment Passenger Side Front Behind Head Light. ** 2 GRAY / YELLOW Wires Are Same Circuit.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
