91 Integra, Python 460HP
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25154
Printed Date: May 11, 2026 at 8:27 AM
Topic: 91 Integra, Python 460HP
Posted By: tribb333
Subject: 91 Integra, Python 460HP
Date Posted: January 23, 2004 at 6:12 PM
Hi, I recently had the python 460hp alarm installed in my 91 integra. I think it's a great alarm, other than the fact that when it goes off, i cant seem to shut it off with the remote, i have to wait for it to finish.  I was curious if anybody else has had this issue, and if i am even able to change that, or if its just the way that this particular alarm is set up.  Any help would be appreciated.  Thanks.
Posted By: advanced529
Date Posted: January 23, 2004 at 9:30 PM
Almost all the times that I had problem with disarming while alarm was sounding ,,,, was always a grounding issue with the alarm brain.. Have your installer check out the problem,, he probably has an insufficient ground for the brain..
Good luck    J
