97 century
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25245
Printed Date: April 02, 2026 at 1:21 PM
Topic: 97 century
Posted By: safco00
Subject: 97 century
Date Posted: January 25, 2004 at 9:56 AM
Anyone have to diagram for a 97 century?  Or can i use the 98's diagram?  Thx much
Posted By: jrilla
Date Posted: January 25, 2004 at 10:24 AM
97 is same as 98 except parking lights may be brown found in the kick instead of at the switch, and trunk may be black instead of brown.
J Rilla
Owner/Installer
Posted By: Teken
Date Posted: January 25, 2004 at 12:51 PM
Buick
Century
1997-2000
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   YELLOW
IGNITION SWITCH HARNESS *
Ignition #1:
   PINK
Ignition #2:
   DARK GREEN
IGNTION SWITCH HARNESS
Ignition #3:
   N/A
Accessory:
   ORANGE
Brake Light:
   WHITE
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
   WHITE
AT ICM TOP CENTER REAR OF ENGINE
Parking Lights:
   LIGHT BLUE
AT HEADLIGHT SWITCH
Headlights:
OEM Alarm Disarm:
   LT. GREEN
DRIVER'S KICK PANEL
OEM Alarm Arm:
   N/A
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
   * This Vehicle Is Equipped With GM's VATS Passive Security Theft System. See Note # 237 - Bypassing VATS Passive Theft Security System Diagram. Some vehicles may be equipped with a transponder - See Note#144
Buick
Century
1997-2000
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   RED
Starter Kill:
   YELLOW
Ignition +12 Volts:
   PINK
Dome Lights/Superv:
   DK. BLUE/WHITE
AT BCM LEFT SIDE OF DASH I/P
OEM Horn:
   BLACK
IN STEERING COLUMN HARNESS
Power Lock:
   RED / BLACK (-)
DRIVER'S KICK OR BCM BEHIND THE DASH
Power Unlock:
   ORANGE / BLACK (-)
TO THE LEFT OF THE STEERING COLUMN*
Trunk Release:
   BLACK/ WHITE (+)
AT TRUNK RELEASE SWITCH
Alarm Input Wire:
   DK. BLUE/WHITE
Notes:
* See Note # 201 - Negative Pulse Door Lock Diagram
As J Rilla stated, the wire colors may be different in the 98. Varify the operation of each wire, if in doubt as you would normally do.
Regards
EVIL Teken . . .
