avital 4100 and window rollup
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25349
Printed Date: May 15, 2026 at 5:12 PM
Topic: avital 4100 and window rollup
Posted By: godsegoizhuge
Subject: avital 4100 and window rollup
Date Posted: January 27, 2004 at 9:04 AM
Got a guy with an 04 grand am. We installed the keyless entry and trunk release. Now he wants to add a window roll up to this vehicle. My question is this, how would i do this? The remote start system only has the trunk release option output, nothing else for adding an additional item or channel. How would I install the roll up module? He just wants it to roll up when the door locks.
Posted By: tblanning
Date Posted: January 27, 2004 at 9:50 AM
just use your door lock output from your keyless entry unit split the wire
should diode isolate or use relay
Posted By: Big Dog
Date Posted: January 29, 2004 at 11:07 AM
Seeing that you're installing an Avital get a 529T from DEI who also manufactures the Avital. This is a window rollup module which will roll up two windows. It can be activated by connecting to the doorlock output of the Avital.
