2000 volkswagon jetta window rollup
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25496
Printed Date: May 13, 2026 at 11:18 AM
Topic: 2000 volkswagon jetta window rollup
Posted By: mobiletoys2002
Subject: 2000 volkswagon jetta window rollup
Date Posted: January 29, 2004 at 3:46 PM
What is the best way to roll these windows up i know if i extend the pulse on the door lock wires the windows will go up but do i use a pulse timer or what?? I need the best way to do it!
Date Posted: January 29, 2004 at 9:32 PM
any ideas anyone??
Date Posted: January 30, 2004 at 10:11 AM
someone throw an idea, I need to do this remote start in a few hours!
Posted By: nasdaqbull
Date Posted: January 30, 2004 at 10:42 AM
I'm not an installer so I can't really help you. I imagine you would either need a timer or some pressure sensor to stop rolling the windows up when they reach the top. I know they have window roll-up modules that do this and they integrate pretty easily.
Sorry I couldn't be more help but good luck.
nasdaqbull.
------------- nasdaqbull
Date Posted: January 30, 2004 at 10:45 AM
no window module needed in this car, but i was thinking maybe a pulse timer!! This car rolls up window through door lock wires it is multiplexed
Date Posted: January 30, 2004 at 11:00 AM
Thanks nasdaq though I apreciate the post!
Posted By: Dolomite
Date Posted: January 30, 2004 at 11:59 AM
You could use a capacitor and a relay to create a delayed pulse for as long a duration as you need.
Posted By: Patel
Date Posted: January 30, 2004 at 2:58 PM
need a 20 second pulse timer to close the 4 windows then the sunroof, in the cars lock wire (be sure to diode isolate
you can use the lock wire to trigger or an aux channel
u can do the same for window roll down on a separate channel of course
no need for a pressure sensor, the car has them built in
Posted By: Patel
srry 15 sec timer
Posted By: kwalton
Date Posted: January 31, 2004 at 10:02 PM
the best way to do them is through a validity output from the alarm. that way they will only work as long as you are pressing the button.
Posted By: bmf1000d
Date Posted: January 31, 2004 at 10:07 PM
I would go with a timer myself. You may have to adjust the time over the years for motor wear and tear but hey its all good
------------- "Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
