ONstar??
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25523
Printed Date: May 13, 2026 at 3:17 AM
Topic: ONstar??
Posted By: 455regalmike86
Subject: ONstar??
Date Posted: January 29, 2004 at 8:50 PM
has anyone had n e problems wiring to the ignition of cars with onstar??  I didi a 02 deville and I am getting a code that says service theft system??  If i just disconnect the wires and take of the battery terminal will it reset...if I do disconnect it will i have to deal with onstar coming on and all that crap??  if n e one has any ideas please help
Pure adrenaline attached to a license plate...isn't it time you experienced one yourself???
Posted By: misterjimbo
Date Posted: January 29, 2004 at 9:04 PM
had a similar problem with o4 gtp. what bypass did you use?
Date Posted: January 29, 2004 at 9:20 PM
what code came up?? how didi you get rid of it??
Posted By: bmf1000d
Date Posted: January 29, 2004 at 11:39 PM
are you wiring a RS or an alarm?
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Date Posted: January 30, 2004 at 12:45 AM
actually it was a satellite radio that was installed...I posted it into this forum because i wanted ot know is someone had n e of the same problems when doing a remote start or alarm....that's when it would be most likely to come up...it wasn't my idea to wire it to the ignition.....so that's why I Am asking this question here
Posted By: prdjr165
Date Posted: January 30, 2004 at 9:18 PM
I did a remote start on a 2002 DeVille without any On star problems.
Date Posted: February 02, 2004 at 7:39 PM
the problem i had would not be of any help sorry
Posted By: auex
Date Posted: February 02, 2004 at 9:03 PM
With the door closed, crank the engine (don't start or it shouldn't start with the light on anyways) and leave the key in the ignition for fifteen to twenty minutes. The light will go away.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
