2004 hyandai accent
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25670
Printed Date: May 11, 2026 at 4:14 AM
Topic: 2004 hyandai accent
Posted By: heavyhopper
Subject: 2004 hyandai accent
Date Posted: February 01, 2004 at 3:38 PM
need alarm/autostart wiring diagram, thanks
Posted By: bmf1000d
Date Posted: February 01, 2004 at 3:45 PM
WIRE COLORSLOCATION
12 VOLTS CONSTANTREDIGNITION SWITCH HARNESS
IGNITION 1GREENIGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1YELLOWIGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2BLUEIGNITION SWITCH HARNESS
STARTERWHITEIGNITION SWITCH HARNESS
PARKING LIGHTSGREEN/ ORANGE (L) AND GREEN/ BLACK (R)  (+)DRIVERS KICK PANEL
POWER LOCKADD ACTUATORIN DRIVERS DOOR
POWER UNLOCKADD ACTUATORIN DRIVERS DOOR
DOMELIGHTGREEN (-)DRIVERS KICK PANEL
BRAKEPINK/BLACKBRAKE PEDAL SWITCH
HORNBLUE/ORANGESTEERING COLUMN
TACH SENSORGREYECM UNDER DRIVERS DASH PIN 8
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Date Posted: February 01, 2004 at 4:11 PM
bmf1000d wrote:
WIRE COLORSLOCATION
do know if it needs a bypass for autostarter?
