555G problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25690
Printed Date: May 10, 2026 at 6:23 PM
Topic: 555G problem
Posted By: csorb
Subject: 555G problem
Date Posted: February 01, 2004 at 9:25 PM
Hi. We're installing a remote mstarter into a 2001 Pontiac Montana. The 555G does not seem to be programming. The little led blinks for a second during programming and does not learn diddly. I checked all my connections and all seem to be correct. Any help would be appreciated
Posted By: Big Dog
Date Posted: February 01, 2004 at 9:50 PM
First of all, be sure the jumper is set to DATA.
Secondly, do the entire remote start and 555G install with the exception of the BLUE status wire.
Thirdly, insert the key, GROUND THE BLUE STATUS WIRE OF THE 555G, now remote start the vehicle.
That's it!
Remove the key, connect Blue status wire of the 555G to the groundout wire of the remote starter and test.
------------- Prepare your future. It wasn't the lack of stones that killed the stone age.
Posted By: csorb
Date Posted: February 02, 2004 at 2:49 PM
Found the problem. We substituted the Blue/black on the 552t with the blue (from the brain) Apparently this car needs to see the 555g Earlier than the ign 3 output provides. Thanks for your help.
Posted By: prdjr165
Date Posted: February 02, 2004 at 5:18 PM
How was the install?I am doing a 2001 montana on wednesday.
