94 Mitsubishi Chariot (Spacewagon) tach w
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25852
Printed Date: April 08, 2026 at 7:48 PM
Topic: 94 Mitsubishi Chariot (Spacewagon) tach w
Posted By: chariot1994
Subject: 94 Mitsubishi Chariot (Spacewagon) tach w
Date Posted: February 04, 2004 at 5:32 PM
 Is there anyone out there that can please tell me where the tach wire is located and what color it is in a 1994 Mitsubishi Chariot (Space Wagon). Many thanks to anyone that can help me
Posted By: Teamrf
Date Posted: February 04, 2004 at 6:29 PM
What kind of alarm are you using? Does it have a voltage sense on it? Most times you can find the  tach wire behind the instrument cluster with the RPM scale on it. If you are having a hard time finding that wire, I would suggest you use voltage sensing if that is an option on your alarm.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Date Posted: February 04, 2004 at 6:38 PM
 Hi to the rookie, The alarm is a clifford concept 300 & a clifford intellistart 4, If you can help me,many thanks
Posted By: mobiletoys2002
Date Posted: February 04, 2004 at 6:42 PM
hey why not go to an injector use the uncommon color wire for tach ! Each injector will have one color that does not change out of 2 wires on each injector use the different color one! This wire will provide pulses for a tach signal this wire goes directly to the ecm to control the injectors!
