2003 PT Cruiser Dome Light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25867
Printed Date: April 08, 2026 at 12:23 PM
Topic: 2003 PT Cruiser Dome Light
Posted By: FredA1974
Subject: 2003 PT Cruiser Dome Light
Date Posted: February 04, 2004 at 9:31 PM
I have installed a Honet (DEI) Remote Start/Alarm. I have noticed that after the remote start remotely turns off after 12 mins.  the alarm goes off. I believe it doing this because I did not hook up the dome light supervision from the alarm. I had a hard time finding the door trigger wire so I did not bother looking for this wire since everything I read said there was 3 different wires and I had none of them. I did find 1 yellow wire in the pass. kick panel that worked with all the doors and hatch. I was wonding if this wire will control my dome light supervision. Also if this is the cause of the alarm going off after the remote start turns off.
If anyone can fill me in that would be great. Also can I remove the factory brain? We I disconnected it nothing in the car worked. If it is not possible then no biggy but every once in a while it activates and I have to use the factory remote to turn it off. Thanks for all your help.
Posted By: Teamrf
Date Posted: February 04, 2004 at 9:51 PM
You may want to put a diode on that wire. So it wouldn't kick back to the alarm. But other than that you shouldn't have a problem with your alarm going off.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Date Posted: February 04, 2004 at 11:26 PM
Diode on what wire? Is the yellow wire I am using the right wire I should be using for the door trigger? And is it ok to hook the dome light supervision to it (I have not yet done)?
Posted By: bmf1000d
Date Posted: February 05, 2004 at 9:00 AM
Dome  Lights/Superv:
Tan & Tan/Blue (-)
Keyless module above radio
Must diode isolate. Tan wire is the door trigger for the Drivers door and the Tan/Blue is for all other doors.
you dont need to disconnect the factory unit just leave it in there cause more than alrm wiring runs through there.
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
