Clifford RSX 3.5 Trunk Wires
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25878
Printed Date: March 30, 2026 at 3:17 PM
Topic: Clifford RSX 3.5 Trunk Wires
Posted By: JustDoIt2
Subject: Clifford RSX 3.5 Trunk Wires
Date Posted: February 04, 2004 at 11:19 PM
Hi, I can Not find which wire DO i have to connect to the trunk, Because there is one that goes to the hood, but there should be another one that goes to the trunk, because the LED shows Trunk and Hood
Does anybody know, because I cant find it.
Posted By: Teamrf
Date Posted: February 04, 2004 at 11:26 PM
Yea there is a blue wire comming off the alarm use that one. It should be something about instant trigger...or zone trigger. I know it's a blue wire on the alarm use that one. Hope this helps...if you need any other help just post to the board..we can help ya...good luck. Let me know how this turns out for you.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: kenmci
Date Posted: February 04, 2004 at 11:34 PM
It will be as Teamrf said, the blue wire on the main wiring harness next to the green door trigger wire.  This wire is neg. trigger so make sure you hook it up to the right wire, just post if you need additional help.
Date Posted: February 05, 2004 at 10:38 AM
OK, thank you Guys, I will do it now and I will post the results. thank you
