need help with Hornet 554t problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25954
Printed Date: April 01, 2026 at 6:43 AM
Topic: need help with Hornet 554t problem
Posted By: hadehatch
Subject: need help with Hornet 554t problem
Date Posted: February 06, 2004 at 3:02 PM
hey guys, ive been reading this fourm for a while and picked up a lot of great information.. today i installed a hornet 554t in my 92 civic, no remote start. everything works except the pager is acting strange. when i put in the battery it shows the speaker and unlock icons all the time.. even when i arm the car.. plus i get no feedback from the car to the pager.. all the buttons work along with their respective features though.. any ideas? any help would be appreciated.. thanks
-Cosmin
Date Posted: February 06, 2004 at 9:48 PM
still didnt figure this out, called a few installers and they tried to sell me a new remote for around $75.00.. if there is another way to fix this please let me know.. if not.. is there any place i can get these remotes for less? thanks in advance.
Date Posted: February 09, 2004 at 1:11 PM
still waiting on a suggestion.. if you can help i would appreciate it.. thanks
Posted By: Velocity Motors
Date Posted: February 09, 2004 at 1:18 PM
If you purchased this from a dealer, they should be able to get you a replacement remote for free as part of warranty. The first thing I would try is to remove the fuse from the CPU and the battery from the remote control and try to reprogram the remote once again. If problem persists, then get a new remote through warranty.
Date Posted: February 10, 2004 at 11:53 PM
ok if the alarm was sitting outside a car for a while (no power) and i recently installed it would i haev to program the remote?? it performed the basic functions as soon as i powered it up... let me know
thanks
Date Posted: February 11, 2004 at 2:54 PM
Not sure with DEI remote's and CPU's. Some units loose any memory of the remote's after a certain amount of time while other's retain all remote's in their memory forever until you reprogram more remote's into it's memory. Nonetheless, I would still go back to the dealer and get them to take a look at the remote control and the way it's functioning.
Posted By: x6369x
Date Posted: February 13, 2004 at 11:54 AM
Try re-programming the remote. Of all of the DEI alarms that I've done that were brand-new in the box, they all came programmed. Where'd you get the alarm? Maybe they had to "borrow" the remote for another customer, and threw in a replacement when they got another remote in stock.
Friends Don't Let Friends Bump Stock.
Date Posted: February 13, 2004 at 7:07 PM
well i got the alarm from a friend after he junked his car.. he had it installed at a shop.. i installed it in my car.. the warrenty probably wouldnt cover it anymore... ill have them check it out after i put the engine in my car.. thanks for the replies!!!
Posted By: mecpcert_1
Date Posted: February 15, 2004 at 2:28 AM
try unplugging the brain, the antenna(make sure it is not torn or ripped) and take out the battery to the remote.
plug the brain and antenna back in, put the battery back in the remote AND within the "little musical that plays", hit the lock button.
 if this does not work, time for a new system.
       good luck and have fun!!!!
do it right the first time....less warranty work=more money!:)
