Delta Panther Pro 5005 in 2001 Blazer
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=25978
Printed Date: April 02, 2026 at 1:38 AM
Topic: Delta Panther Pro 5005 in 2001 Blazer
Posted By: Lovetorace
Subject: Delta Panther Pro 5005 in 2001 Blazer
Date Posted: February 06, 2004 at 10:33 PM
 I am wanting to put long range antenna above mirror & module in center console. Are there any problems with cutting & lengthening the antenna wires? What circuits should be isolated with diodes and or relays? Can I hook up power windows (have window roll up module), door locks, park lights, and horn right to wiring at BCM? Do you have wiring diagram fo 2001 Blazer with passlock but not with keyless entry
Posted By: Craig3708
Date Posted: February 07, 2004 at 6:29 PM
Chevrolet
S-10 Blazer
1995-2001
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS **
Ignition  #1:
PINK
Ignition #2:
PNK/WHITE or WHITE
IGNITION SWITCH HARNESS ***
Ignition  #3:
N/A
Accessory:
ORANGE
IGNITION SWITCH HARNESS (HEAT/AC)
Brake  Light:
WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE
AT POWERTRAIN CONTROL MODULE *
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH
Headlights:
YELLOW (+)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
N/A
IN SCHEMATICS
OEM Alarm  Arm:
N/A
NO OEM ALARM PRESENT
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * WHT/BLK At Distributor Ignition Module Can Also Be Used For Tach. Ignition Coil And Distributor Module Both Located On Passenger Side Of Engine. ** 1998+ Vehicle is equipped with PASSLOCK II Anti-theft system. See Note # 113 - Bypassing PASSLOCK II Theft Deterrent System Diagram. *** This Wire Powers the PCM in the Vehicle and Must Be Active in Both " Start" and "Run".
Chevrolet
S-10 Blazer
1995-2001
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED (2)
Starter  Kill:
YELLOW
Ignition  +12 Volts:
PINK
Dome  Lights/Superv:
WHITE (-)
AT PIN SWITCH OR COURTESY LIGHT
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
L BLUE
INSIDE OF LOOM IN DRIVERS DOOR OR
Power  Unlock:
WHITE
AT KEYLESS ENTRY MOD. UNDER DASH ****
Trunk  Release:
BLACK/ WHITE (+)
AT TRUNK RELEASE SWITCH
Alarm  Input Wire:
WHITE (-)
Notes:
**** See Note #202 - Positive Pulse Door Lock Diagram.
Posted By: bmf1000d
Date Posted: February 07, 2004 at 6:45 PM
As for making the cables longer there not long enough? Sure you can add a window roll up as for the vehicle wires
Windows UpLF=Dark Blue, RF=Light Blue, LR=Dark Green, RR=Light Green
Windows DownLF=Brown, RF=Tan, LR=Purple, RR=Purple
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Date Posted: February 07, 2004 at 7:04 PM
                  Thanks for info!
 As for the extended range antenna, the cable is approximately 3 feet too short. It is a 5 wire bundle with small plugs on either end. I was thinking of cutting in 2 & soldering 3 feet in center.
I just didn't know if it would effect range or not.
                         Thanks Guys
