door lock , what type
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26011
Printed Date: April 03, 2026 at 5:35 AM
Topic: door lock , what type
Posted By: ezeekel
Subject: door lock , what type
Date Posted: February 07, 2004 at 4:59 PM
this table shows two different door locks
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1998&make=Chevrolet&model=C/K%20Pickup&ID=17378&type=Alarm
what one should i use?
what is the" W/o Keyless Entry Reverse Polarity (5 Wire) "
i currently do not have keyless entry
my wiring schem. shows  a wht wire and lt blue from switches to door lock relay 4 door.
does this mean i use the -trigger or +
Thanks ezeekel
Posted By: bmf1000d
Date Posted: February 07, 2004 at 5:57 PM
If your truck did not come with keyless entry then you have 5 wire door locks which is
https://www.the12volt.com/doorlocks/page3.asp#5w
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
