Info Needed - FM-5000 unit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26014
Printed Date: April 03, 2026 at 9:06 AM
Topic: Info Needed - FM-5000 unit
Posted By: Mad Scientists
Subject: Info Needed - FM-5000 unit
Date Posted: February 07, 2004 at 5:57 PM
 Vehicle is 1997 Sebring Convertible. Alarm appears to be a Baretta FM-5000 system as pictured here..
https://www.itsrealstuff.com/html/alarm_pagers.html
 Remote looks similiar and brain looks identical to system installed in vehicle; horn looks somewhat different. I suspect system is identical to Commando FM-5000 system - replacement remote looks identical.
https://www.commandocaralarms.com/itemdetails.asp?Productid=733
 Difference between Baretta remote and Commando remote is the words 'FM two-way' in upper left corner of display. I would assume that remotes are interchangeable.
 Vehicle/system has intermittant problems; remote start works intermittantly, alarm fails to set on occasion and needs to be cycled to arm. Reaching under the dash and shaking system wiring sometimes causes remote start to work.
Pulled interior apart today to inspect install. Found 'spit and twist', power wiring extended with speaker wire, some connections made with what appear to be crimped wire nuts (crimp caps?), one fuse holder appears that the ATC style fuse contained inside has melted and has green colored plastic running out of it, and my personal favorite, numerous connections where the 'spit and twist' is taped over, then a 'tie wrap' is tightly installed over connection.
 What I'm looking for in owners manual/install manual for unit, clarification on whether the Baretta and Commando systems are the same, and any other helpful hints/suggestions.
 Thanks in advance,
 Jim
Posted By: bmf1000d
Date Posted: February 07, 2004 at 6:05 PM
YEs they are the same. Its like Viper and Sidewinder. as for the install manaual
https://www.commandocaralarms.com/manuals/fm-5005manual.pdf
And for your vehicle
Chrysler
Sebring Convertible
1996-2000
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS *
Ignition  #1:
D BLUE
Ignition #2:
BLACK/ ORANGE
IGNITION SWITCH HARNESS (HEAT/AC)
Ignition  #3:
N/A
Accessory:
BLACK/ WHITE
Brake  Light:
WHITE/ TAN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLACK/ GRAY
AT DISTRIBUTOR (6 CYLINDER)
Parking Lights:
BLACK / YELLOW (+)
GRAY # PIN CONN. AT FUSE BLOCK
Headlights:
VIOLET/WHITE (LO) &
RED / ORG (HI) (+) AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
LT. GREEN/ ORANGE
# PIN BLACK CONNECTOR
OEM Alarm  Arm:
LT. GREEN/ ORANGE
IN DRIVER'S KICK PANEL ***
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * If This Vehicle Has A Gray Ignition Key, Then It Is Equipped Wiith Chrysler's Smart Key Engine Immobilizer. See Installation Note #144 - Bypassing Transponder Passive Theft System Diagram.
Chrysler
Sebring Convertible
1996-2000
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED (2) & BLACK
Starter  Kill:
YELLOW
Ignition  +12 Volts:
D BLUE
Dome  Lights/Superv:
YELLOW (-)
BLACK 3 PIN CONN. IN DR. KICK PANEL
OEM Horn:
BLACK/ RED (-)
STEERING COLUMN HARNESS
Power  Lock:
SINGLE WIRE SYSTEM
# PIN CONNECTOR AT BODY CONTROL
Power  Unlock:
WHITE/ LT. GREEN
MODULE IN DRIVER KICK PANEL **
Trunk  Release:
L GREEN/ BLACK (+)
AT RELEASE SWITCH
Alarm  Input Wire:
YELLOW (-)
Notes:
** See Note # 217 - Cirrus/Sebring/Stratus/Breeze Single Wire Single Wire Door Lock Diagram, A Positive Pulse Through A 2.7 K-Ohm Resistor for Unlock, A Positive Pulse Through A 620 Ohm Resistor for Lock. *** Single Wire System, A Positive Pulse Through A 940 Ohm for Arming Alarm, A Positive Pulse Through A 270 Ohm for Disarming Alarm).
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Posted By: jrilla
Date Posted: February 07, 2004 at 7:27 PM
I wouldn't put any hope in getting it working consistently. Those are pretty poor units. i had one and it just never worked well. Great range though
J Rilla
Owner/Installer
Date Posted: February 09, 2004 at 7:05 PM
 Thanks for the responses... already had the 5005 manual, but was hoping someone knew where there was a 5000 owners and install on the web. When the system was working correctly, it worked pretty well. I suspect that once I correctly connect all the wiring (for me, 'correctly' means soldered & heatshrinked) that the system will work correctly again.
 If anything, I was surprised at the quality of the install.. if it was an owner install, then I'm surprised that they did at least part of it right.. if it was a pro install, then I'd like to know where it was done so I could stay away from them.. (not that I let anyone do anything to my cars anyway..<grin>)
 Thanks,
Jim
Posted By: Velocity Motors
Date Posted: February 11, 2004 at 7:07 PM
Hey Jim, The wiring information is on the back of the CPU and the programming information I have, just let me know what your after, remote learning, tach learning, etc.....
