2001 Grand Am R/S light problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26083
Printed Date: April 05, 2026 at 1:33 PM
Topic: 2001 Grand Am R/S light problems
Posted By: Craig3708
Subject: 2001 Grand Am R/S light problems
Date Posted: February 08, 2004 at 7:48 PM
I installed a CT-3300 with the passlock11 bypass, matching the resistance with in 1%. The problem is after the car is driven for about 10-12 min then the SES, ABS, security, and LOW TRAC lights all come on at the same time. when you shut the car off and restart it , it will do the same all over, all is fine for about 10-12 min. This all happened about 3 weeks after I installed the r/s. Anyone with any ideas?
             Craig...
Posted By: daniel2002p
Date Posted: February 08, 2004 at 8:11 PM
make sure that the resistance is only being broadcasted when the rs is operating the car.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Date Posted: February 08, 2004 at 8:18 PM
I'll double check, but i'm pretty sure it is. The confusing part is that it didn't happen for 3 weeks and only happens after its been driben awhile.
              Craig.
