2004 camry wire info
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26121
Printed Date: April 06, 2026 at 4:26 AM
Topic: 2004 camry wire info
Posted By: MikeHusain
Subject: 2004 camry wire info
Date Posted: February 09, 2004 at 9:59 AM
I was wondering if anyone had the wire info for a 2004 toyota camry LE.  Need to do a remote start.  thanks....
Posted By: draasch
Date Posted: February 09, 2004 at 10:32 AM
here is the 2003 info...see if it will help you:
Make:   Toyota
Model: Camry
Year:    2003
This Database Was Last Updated On:    6/9/2003
Index #: 885
Alarm
Constant 12 volts WHITE/ RED OR WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ RED IGNITION SWITCH HARNESS
Starter BLACK / YELLOW AND BLACK /WHITE AT IGNITION SWITCH HARNESS *
Dome Light GREEN/ RED (-) IGNITION KEY CYLINDER LIGHT
Trunk Pin Switch GREEN / WHITE (-) AT THEFT DETERRENT E.C.U. **
Parking Lamp GREEN (+) AT THE BACK SIDE OF E.C.M.***
Power Lock BLUE / YELLOW 13 PIN GRAY CONN. IN DR KICK
Power Unlock BLUE 20 PIN WHITE CONN.IN DR KICK ****
* There Are Two BLACK / YELLOW Wires Please Check. ** Theft Deterrent E.C.U. Is Located Behind Pass Side Dash Top Right. *** E.C.M. Located Above Drivers Kick Panel A Part Of Fuse Box. **** First Pulse Unlocks Driver 2nd Pulse Unlocks The Rest. #201 - See Negative Pulse Door Lock Diagram
Remote Start
Tach Signal WHITE AT DATA LINK CONNECTOR
Ignition #2 BLACK / YELLOW IGNITION SWITCH HARNESS *
Ignition #3 #239
Accessory BLUE/RED IGNITION SWITCH HARNESS
Neutral Safety NON GROUNDING TYPE
Brake Light GREEN / WHITE AT SWITCH ABOVE BRAKE
Reverse Light WHITE/ RED DRIVERS DOOR SEAL HARNESS
Rear Window Defrost
#239- See Immobilizer Bypass Diagram (Some Vehicles Reported W/O) Omega Part:DB-PKT All Toyota/Lexis 98-02 (No Key Required). * Cold Start Wire BLACK / YELLOW There Are Two BLACK / YELLOW Wires One Tests Like A Starter Wire The Other Like A Ignition ,Please Check.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
