UltraStart 93 Trans am
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26134
Printed Date: April 06, 2026 at 3:33 PM
Topic: UltraStart 93 Trans am
Posted By: clearman
Subject: UltraStart 93 Trans am
Date Posted: February 09, 2004 at 12:26 PM
I have an ultrastart 2256m installed on my 93 pontiac trans am. It has been working fine, until now. Every time the parking lights came on or flashed, there was a loud buzzing noise coming out of the box. I unplugged it. Now, when I plug it in, the alarm chirps constantly until I turn the key in the ignition. I have already had to get a new brain, the last one the lock circuit was bad. Is this a faulty one as well. If so, is Ultrastart just a POS all together, or do I just have bad luck?
Posted By: clearman
Date Posted: February 09, 2004 at 12:50 PM
It will do nothing but chirp, until the key is turned. The siren has been malfunctioning a little, it has not always chirped when it should have lately. Did that circuit go bad in the brain?
Posted By: clearman
Date Posted: February 09, 2004 at 2:54 PM
Or, could this be some type of feedback causing it to do this?
Posted By: JWorm
Date Posted: February 09, 2004 at 9:25 PM
I install Ultrastart everyday. The loud buzzing is usually related to a bad ground.
Posted By: clearman
Date Posted: February 10, 2004 at 2:09 AM
Know anything about the constant chirping? It speeds up when I unplug the lock/unlock wires, and slows down when I plug them back in.
Posted By: Puddy905
Date Posted: March 21, 2004 at 10:34 AM
It's a bad ground....my 96 did the same thing with my crappy OMEGA remote start/Freedom alarm, it also went off for no reason a lot. Throwing the entire system in the garbage and buying a Viper has solved the problem. lol
