04 Hyundai Elantra Wire Diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26160
Printed Date: April 08, 2026 at 7:57 PM
Topic: 04 Hyundai Elantra Wire Diagram
Posted By: a2k3xrs
Subject: 04 Hyundai Elantra Wire Diagram
Date Posted: February 09, 2004 at 4:09 PM
Looking got the wire diagram for a 04 elantra.
alarm and remote start.
Thanks!
Posted By: mxxmikexx
Date Posted: February 10, 2004 at 12:45 PM
Audiovox Tech Support 505645 FaxBack ID:
HYUNDAI ELANTRA 2004 4DR SEDAN
Security Color Polarity Location
Battery RED (+) IGNITION SWITCH HARNESS
Ignition 1 RED (+) IGNITION SWITCH HARNESS
Starter 1 WHITE (+) IGNITION SWITCH HARNESS
All Door Trigger YELLOW (-) AT ETACS MODULE
- Note ETACS MODULE LOCATED BEHIND THE ASHTRAY
Trunk Trigger GREEN/ BLACK (-) AT ETACS MODULE
Hood Trigger GREEN/ BLACK (-) AT ETACS MODULE
- Note ONLY WITH FACTORY ALARM
Alarm Disarm RF ONLY!!!!!!!!!!
Alarm Arm RF ONLY!!!!!!!!!!
Parking Lights GREEN/ ORANGE (+) AT FUSE BOX BELOW DRIVER'S SIDE DASH
Remote Start
Ignition 2 BLUE/BLACK (+) IGNITION SWITCH HARNESS
Accessory 1 RED (+) IGNITION SWITCH HARNESS
- Note BATTERY, IGNITION AND ACCESSORY WIRE ARE ALL RED AT THE IGNITION SWITCH HARNESS. MUST TEST
THESE WIRES.
Key Sense RED (+) IGNITION SWITCH HARNESS
Tachometer WHITE (AC) AT THE ECM PIN 47 OR AT THE COIL PACK
- Note THE ECM IS LOCATED ABOVE THE DRIVER'S KICK PANEL
Speed Sense GRAY/ORANGE (AC) AT CRUISE CONTROL MODULE OR AT THE INST. CLUSTER
- Note CRUISE CONTROL MODULE IS LOCATED BELOW THE RADIO
Brake Lights WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights RED / GREEN (+) IN HARNESS IN DRIVERS KICKPANEL
Horn RED (-) AT STEERING COLUMN HARNESS
Doorlocks/Windows
Power Unlock YELLOW (-) AT ETACS MODULE
- Note THIS VEHICLE COULD ALSO COME WITH A CENTRAL LOCKING SYSTEM THAT WOULD REQUIRE AN ACTUATOR
IN THE DRIVER'S DOOR
PowerLock YELLOW/RED (-) AT ETACS MODULE
LF Window Up BROWN (REV) AT MASTER SWITCH
LF Window Dn ORANGE (REV) AT MASTER SWITCH
RF Window Up GREEN (REV) AT MASTER SWITCH
RF Window Dn GRAY (REV) AT MASTER SWITCH
LR Window Up PINK (REV) AT MASTER SWITCH
LR Window Dn BLUE (REV) AT MASTER SWITCH
RR Window Up BROWN (REV) AT MASTER SWITCH
RR Window Dn WHITE (REV) AT MASTER SWITCH
Convenience
Headlights-Lo WHITE (-) AT VEHICLE LIGHT SWITCH
Trnk Release YELLOW/BLACK (+) AT TRUNK RELEASE SWITCH
Modules
Module 1 ETACS MODULE LOCATED BEHIND THE ASHTRAY
Audio/Mobile Video
Battery LIGHT GREEN (+) RADIO HARNESS
Accesory BROWN (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination DARK GREEN / WHITE (+) RADIO HARNESS
Dimmer DARK GREEN/ BLACK (+) RADIO HARNESS
LF Speaker (+) GREEN/ RED
LF Speaker (-) LIGHT GREEN / WHITE
------------- Mike Battaglia
Specialized Car Audio
Bensenville IL 60106
