Help with 99 dodge Avenger...
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26243
Printed Date: April 08, 2026 at 12:38 PM
Topic: Help with 99 dodge Avenger...
Posted By: extremeavenger
Subject: Help with 99 dodge Avenger...
Date Posted: February 10, 2004 at 7:49 PM
Hey peeps new to this site....got a Commando car alram and remote start system and I am looking for a wiring diagram for a 1999 dodge avenger ES but cant find one anywhere...can you guys help me and also let me know if I am going to run into any problems that you can think of installing this thing considering I have never done this before...failry simple..I hope.
Posted By: S.I.Autosports
Date Posted: February 11, 2004 at 7:01 AM
That car shouldnt be too bad, but take your time and double check all of the wires with a multi-meter.
AVENGER 1995-2000
WIRE COLORSLOCATION
12 VOLTS CONSTANTWHITEIGNITION HARNESS
IGNITION 1BLACK/ WHITEIGNITION HARNESS
ACCESSORY /HEATER BLOWER 1BLUE/BLACKIGNITION HARNESS
STARTERBLACK/ REDIGNITION HARNESS
PARKING LIGHTSGREEN / WHITE(+) 18 PIN BLACK CONN. AT FUSE BLOCK
DOMELIGHTRED / GREENDRIVERS KICK PANEL
POWER DOOR LOCKBROWN / WHITEDRIVERS KICK PANEL OR AT
POWER DOOR UNLOCKBROWNRELAYS BELOW RADIO TYPE B
TACH SENSORWHITE/ BROWNPOWERTRAIN CONT MOD
BRAKE
GREEN(+)BRAKE PEDAL SWITCH
HORN
GREEN/ RED (-)STEER COLUMN
FACTORY DISARM
GREEN / WHITE (-)BLACK 20 PIN CONN.
