2002 Accord Diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26294
Printed Date: April 07, 2026 at 7:21 AM
Topic: 2002 Accord Diagram
Posted By: illmattix
Subject: 2002 Accord Diagram
Date Posted: February 11, 2004 at 4:41 PM
Just wondering if anyone had the security wire guide for an 02 Acoord. Thanks
Posted By: profuse007
Date Posted: February 11, 2004 at 5:07 PM
check the sites vehicle diagram or do a search
Houston,TX
Posted By: Teken
Date Posted: February 11, 2004 at 5:57 PM
Honda
Accord
1998-2002
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   BLACK/ WHITE
IGNITION SWITCH HARNESS **
Ignition #1:
   BLACK / YELLOW
Ignition #2:
   YELLOW
Ignition #3:
Accessory:
   WHITE/ BLACK
Brake Light:
   WHITE/ BLACK
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
   BLUE
AT COIL MODULE
Parking Lights:
   RED / BLACK
AT FUSE BLOCK ON DRIVER'S SIDE
Headlights:
OEM Alarm Disarm:
   BLUE
INSIDE OF DRIVER'S DOOR
OEM Alarm Arm:
   BLUE/WHITE
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
   * This vehicle is equipped with a transponder immobilizer system; See Installation Note #144 - Bypassing Transponder Theft Systems.
Honda
Accord
1998-2002
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   WHITE
Starter Kill:
   BLACK/ WHITE
Ignition +12 Volts:
   BLACK / YELLOW
Dome Lights/Superv:
   BLACK/ WHITE (-)
4 PIN GREEN CONN. IN PASS FUSE BOX
OEM Horn:
   BLUE/GREEN (-)
IN STEERING COLUMN HARNESS
Power Lock:
   BLACK/ BLUE (-)
PASSENGER SIDE FUSE BOX**
Power Unlock:
   ORANGE (-)
Trunk Release:
   WHT/RED+
# PIN GRAY CONN. ABOVE DRIVER'S KICK
Alarm Input Wire:
   BLACK/ WHITE (-)
Notes:
** See Note#201 Negative Trigger Door Locks
