relay help
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26324
Printed Date: April 06, 2026 at 6:07 AM
Topic: relay help
Posted By: tuzzy
Subject: relay help
Date Posted: February 12, 2004 at 2:56 AM
I am trying to use a realay on the clutch switch for a remote start, I need to take a constant output and turn it into a momentary one, I looked over the relay section, can someone tell me what size capacitor to use to get about a seconds worth of juice. thanks.
Posted By: Velocity Motors
Date Posted: February 12, 2004 at 6:42 AM
Does the remote starter you have not have a (-) ground out when running wire ??
Posted By: Big Dog
Date Posted: February 12, 2004 at 2:49 PM
Hi tuzzy,
If you wanna bypass momentarily durng crank, then use the positive crank out on pin 86 and the constant groundout on pin 85. Connect clutch wires to pins 30 and 87. And there you have it . . . momentary clutch bypass!
Prepare your future. It wasn't the lack of stones that killed the stone age.
