Bypass VATS 95 Buick Lesabre
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26376
Printed Date: April 04, 2026 at 11:59 AM
Topic: Bypass VATS 95 Buick Lesabre
Posted By: asab16
Subject: Bypass VATS 95 Buick Lesabre
Date Posted: February 12, 2004 at 11:14 PM
Guys I have a chip/ resister on my ignition key for my  95 LeSabre........ I have the schmatic to cheat the system but just wanted to know after getting the reading for the resister from the key.....in my case its 1.126 OHM............what kind of resister should I get....could someone please help me out (If u have not fiqured out. I am a newbie)  should the resister be 1/4watt or  1/2 watt or 1watt.....and can I use more than one resister to get into my range of 1.126 OHM +/- 10 ohm?
Spoon Feed me please if possible :oops:
thanks
asab16
Posted By: Velocity Motors
Date Posted: February 13, 2004 at 6:40 AM
Use the 1/2 watt resistors and use this chart to help you get what you need as far as the value goes.
Posted By: derek123
Date Posted: February 13, 2004 at 9:19 AM
"1.126 OHM"
maybe you mean mean K Ohm ? (1000 * 1.126 = 1126 Ohm)
the lowest VATS value starts at 392...
Posted By: mecpcert_1
Date Posted: February 15, 2004 at 4:30 AM
as a safe measure, i try to stay within a 5% window.
in this case,  1,126x5%=56.3
        1,126+56.3=1182.3ohms
        1,126-56.3=1069.7ohms
  this is your window of tolerance. make sure your resistor meters between 1,182.3ohms and 1069.7ohms and you should be just fine.
 1/4 watt or 1/2 watt should work just fine. just be careful when soldering as not to burn up the resistor.
 good luck and have fun!!!
do it right the first time....less warranty work=more money!:)
Posted By: asab16
Date Posted: February 15, 2004 at 9:11 PM
Thanks for the replys guys.....Its making things clear.....I just have one question, can  I use more than one resister for example, one 1K and 100 ohm.......Could you guys give me an example  specific to my VATS system as to what combo I should use. Please and tHaNkS    posted_image
Posted By: daniel2002p
Date Posted: February 15, 2004 at 10:36 PM
yes you can, and make sure that if you want the resitances to add up connect the resitors in series, and if you have two 600ohm (for example) resistors and hook them up parallel, you will get 300 ohms.  something like this
1000 ohm     100 ohm
-------0------- -------0-------      Result will be 1100 ohms
       -------0------- 1000 ohm
       -------0------- 1000ohm      Result will be 500 ohms
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
