00 Impala remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26408
Printed Date: April 03, 2026 at 2:17 PM
Topic: 00 Impala remote start
Posted By: buzychristian
Subject: 00 Impala remote start
Date Posted: February 13, 2004 at 4:45 PM
Hi, I have a RS1050 remote start add-on and the problem is that it won't try to start.  i have checked the trigger wire on unit (BROWN / yellow) and on car (blue/white),  checked the 2nd ign wire on unit (pink/white) and on car (dark green), and have grounded the brake wire (green). The LED is flashing erratic, one flash, maybe ten after that or a singal flash and five after that...the LED is dim, cannot hardly see it. Is there anything else I need to buy to get this to work?
Posted By: Velocity Motors
Date Posted: February 13, 2004 at 5:03 PM
What unit are you installing and why would you ground the brake input wire ? This requires a (+) signal and also the 2nd ACC ( BROWN ) wire requires hook up as well, otherwise you will experience a no cranking problem. The starter is a YELLOW wire.
Date Posted: February 13, 2004 at 5:35 PM
Jeff thanks for the reply...well here goes the unit is a stella RS1050...the blue/white wire form unit is connect to the white wire on the brake switch. The pink/white from unit is connect to the dark green on the ign switch I must have the wrong info...Do I need to scrap it and start over?...thanks Virgil
Posted By: tjdurham
Date Posted: February 13, 2004 at 8:46 PM
did you use a bypass as the car has passlock2 you didnt say but that could be the problem
tj
Date Posted: February 14, 2004 at 4:01 AM
tj and tim, thanks for giving me a hand....no i didn't have a bypass for passlock, sorry for being an dummy....could you tell me what need to do......
                       Virgil
Date Posted: February 14, 2004 at 9:28 AM
Use the PLDATA bypass module for the Passlock bypass on this car.
