99 acura integra remote starter!
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26409
Printed Date: April 03, 2026 at 11:12 AM
Topic: 99 acura integra remote starter!
Posted By: tomphamz
Subject: 99 acura integra remote starter!
Date Posted: February 13, 2004 at 6:02 PM
Can anyone help with a 1999 acura integra will be very much appreciated!! oh yeah remote start with alarm system ! Thank you.
Posted By: draasch
Date Posted: February 13, 2004 at 6:28 PM
what is it that you need help with???
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Posted By: tomphamz
Date Posted: February 14, 2004 at 11:12 AM
I think i got all the wires connected properly.But every time i pressed the start button on the remote and the engine will start but it stop few seconds later.
Posted By: kgerry
Date Posted: February 14, 2004 at 1:26 PM
check your tach source or relearn tach, also did you check for the optional alarm module on this vehicle? it may be initiating ignition kill....
Posted By: brianh
Date Posted: February 15, 2004 at 8:26 AM
Sounds like you didnt bypass the transponder anti theft system. You need to get a universal transponder bypass and loop it around the ignition (with a key in the box)in order to bypass that system. Good luck with it.
Brian
owner/installer
Sight & Sound Car Stereo
"all electronic equipment runs off of smoke, once you let it out, it stops working"
Posted By: tomphamz
Date Posted: February 15, 2004 at 1:30 PM
I don't think 1999 acura have anti-theft system! Anybody knows.Thanks.
Posted By: Velocity Motors
Date Posted: February 15, 2004 at 8:15 PM
No, the 1999 Integra did not come with an Immobilizer key system. Make sure that when you learn your tach signal that you have reached the lowest possible RPM while idle. Do this and post your results.
Posted By: tomphamz
Date Posted: February 19, 2004 at 10:51 AM
Thanks guys for all the help! I got it working by relearn the tach after two days messing around with it and now i think i have another problem.This morning started the car by remote inside the house for about 10 minutes  and my daughter came out opened the door, alarm went off and i disarmed it,drove off for about 1 minute all sudden the engine shut itself off.Now i can't even start the car with remote or key in.
