93 VW PASSAT FACTORY ALARM
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26453
Printed Date: April 02, 2026 at 3:35 AM
Topic: 93 VW PASSAT FACTORY ALARM
Posted By: Takeda
Subject: 93 VW PASSAT FACTORY ALARM
Date Posted: February 14, 2004 at 8:57 AM
I need some help with this plz, Does anybody know how to Disable the factory alarm in this car? because I recently got installed another alarm and it seems that theres a conflict between them or something because the factory alarm goes off at any time without any reason the alarm I got installed is an AVITAL 2100 any help would be appreciated.
Posted By: Velocity Motors
Date Posted: February 14, 2004 at 9:17 AM
The OEM alarm disarms only with unlocking of the car. The only way that the OEM alarm will activate is if the hood, trunk or doors would open while the car is locked. It doesn't have an impact or perimeter sensor on it.
------------- Jeff
Posted By: Takeda
Date Posted: February 14, 2004 at 9:56 AM
So do you suggest that has to do with any of the entrances sensors?(hood, trunk) or door triggers? because before I installed the Avital alarm I had no problems.
Posted By: kgerry
Date Posted: February 14, 2004 at 1:52 PM
you may want to diode isolate the doorlock trigger wire from your 2100 to prevent a possible feedback situation....
