01 jetta door triggers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=26458
Printed Date: April 01, 2026 at 10:42 PM
Topic: 01 jetta door triggers
Posted By: Patel
Subject: 01 jetta door triggers
Date Posted: February 14, 2004 at 11:45 AM
Installed a compustart 2WFM-AS in a 01 jetta (standard)
everything works fine, except for the door triggers.
Can't seem to find the triggers for the back doors.
The avoid the dome light delay, i didn't use the blue/gray at comfort module, instead i used the brwn/wht at the courtesy light in the door (isolated). The front two doors were no problem but the back two doors don't have coutesy lights. i checked every wire in the door harness, found nothing.
any help would be apreciated.
Posted By: whitey
Date Posted: February 14, 2004 at 12:41 PM
You half to go in to each rear door and grab the BROWN / white wire a the door module.
------------- Visions Edmonton
Installation Manager, DLS
MECP Certified First Class
Posted By: profuse007
Date Posted: February 14, 2004 at 1:13 PM
jetta w/ pwr windows:
| DOOR TRIGGER|blue/gray *4 |- |comfort module *5 |
*4 This wire will read the dome light delay. The avoid the dome light delay, use the separate door trigger wires and diode isolate each one. They are BROWN / white and are all located in their own door at their own door module. *5 The comfort module is the main control module located under the drivers side of the dash.
jetta w/o pwr windows:
| DOOR TRIGGER|*3 |- |comfort module *2 |
*2 The comfort module is the main control module located under the drivers side of the dash. *3 There are 3 separate door trigger wires in this car. Use all 3 and diode isolate each. The drivers door is BROWN / yellow, the passenger door is BROWN / purple, and the rear doors are BROWN / white.
------------- Houston,TX
Posted By: kwalton
Date Posted: February 15, 2004 at 6:00 PM
The door triggers are behind the metal panel in the rear doors. if memory serves me correctly you have to remove the 10mm bolts to get behind the panel, but be careful because the window track is also bolted to the panel. the wires should be brown and white. good luck.
Posted By: Patel
Date Posted: February 17, 2004 at 11:44 AM
didn't have to bother going to each door
found a tech document that uses 1 non flashing led and a 1K resistor on the door trigger that eliminates the delay
thanks
