Shock Sensor Fading
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=2646
Printed Date: April 03, 2026 at 5:54 PM
Topic: Shock Sensor Fading
Posted By: pcusick3
Subject: Shock Sensor Fading
Date Posted: August 09, 2002 at 12:39 PM
I added a shock sensor to my factory alarm.  I piggy backed off the hood pin sensor.  The sensor it self is attached to the steering column under the dash.  After I installed it, it worked great, I adjusted the sensitivity and tested it multiple times.  Then, after I went for a drive, I tested it again.  It was much less sensitive.  I took the sensor off, and check everything and reinstalled it.  Again, It worked great.
So what I'm thinking is that the vibrations from driving are loosening the sensor.  I attached the sensor with two nylon zip ties.
Any suggestions on how else to install?  Thanks!
Posted By: Velocity Motors
Date Posted: August 09, 2002 at 2:34 PM
Use sheet metal screws instead of zip ties to a flat spot on the under side of the dash.
